98 TJ 4.0 timing - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-17-2001, 12:43 PM
98 TJ 4.0 timing
Any body know the correct procedure for checking the timing on a 98 TJ with 4.0 and a 5-speed. Most every vehicle I have had, there was something you either had to disconnect or disable to check timing. Any help would be appreciated.
Jeeps, Guitars, Jeeps, Guitars,....What else is there????
post #2 of (permalink) Old 05-17-2001, 02:22 PM
Re: 98 TJ 4.0 timing
I don't think you can check the timing, its all done by on board computer. That is if you installed the distributor correctly. Someone correct me if I'm wrong.
Nycjeep88 [img]/wwwthreads_images/icons/smile.gif[/img][img]/wwwthreads_images/icons/cool.gif[/img][img]/wwwthreads_images/icons/wink.gif[/img]
Let's go baja in NYC and see how well your suspension holds up.... [img]/wwwthreads_images/icons/smile.gif[/img]
post #3 of (permalink) Old 05-17-2001, 11:52 PM
nycjeep88 is correct. The timing is non adjustable. It is determined by the crank angle sensor in the bell-housing. The pick-up in the dist. is called the cam angle sensor, and is primarly used to control injector timing. Your 4.0l has sequential port fuel injection, as the injectors are timed relative to the intake stroke. There is a "high altitude" crank angle sensor that advances the timing 8 crankshaft degrees, which is 4 dist. degrees.
dorfs is offline
post #4 of (permalink) Old 05-18-2001, 07:18 AM
I appreciate the replies. I don't have a problem, just did routine maint. and was stumped when I saw label underhood that said no adj. necessary. Once again, thanks.
