How is this for the new belt routing? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-17-2001, 12:33 PM Thread Starter
kutyafal's Avatar
Current one marked 'No A/C':
New belt routing as proposed by Brad Kilby from onboard.air. This would eliminate the need for the second idler pulley and may work with a stock TJ AC belt.
Does it look like everything still turning the same way?
'91 YJ,I-6,2.5" lift,Boomerangs,33s,D30,D35c,Lock-Rights F&R
kutyafal is offline
post #2 of (permalink) Old 05-17-2001, 12:51 PM Thread Starter
kutyafal's Avatar
Re: How is this for the new belt routing?
By the way I just have to take note that Brad is a great guy! He went outside and popped the hood on one of the jeeps in his back yard so he can walk me through the routing. And that without me wanting to buy anything from him. You think 4wdwh or RE would've done the same?
kutyafal is offline
post #3 of (permalink) Old 05-17-2001, 01:16 PM
jeepfiend
Just a thought, and I haven't really messed with any serpentine stuff, but are there spots now where the belt used to pulling to drive a pully, and now will have to push? It looks like before the the crank pully and water pump were set so the crank pulled the water pump, and the new set-up looks like the crank pully pushes the water pump drive. Like I said, I am not totally familiar with the serpentine set ups, but it makes sense that a belt has to pull a corresponding pully.
Cage Up, Wheels Down
Jeepfiend
All my Jeeps are in pieces!
post #4 of (permalink) Old 05-17-2001, 01:27 PM
deleted cause I screwed up
jimmythetech is offline
post #5 of (permalink) Old 05-17-2001, 01:31 PM
One thing you will need to watch out for is belt vibration. The lengths of belt between each pulley are carefully engineered so that they will not flap when the belt is tensioned properly. If you mess around with the lengths you could get some funky vibrations that will destroy the belt and bearings in the accesory in short order. Another thing is that a belt is like a rope, you can't push it or it will slip. So plan accordingly.
Regards,
Josiah
Hillsboro, OR
1955 Willys CJ5 Buick 225 V6 160HP 270ft-lbs, T90 trans, Warn OD, PTO winch, Spicer 18 T Case, RS9000's, Dana 25F/ 44R,
5.38:1 gears, 11" brakes, Bestop Supertop, Hurculiner
post #6 of (permalink) Old 05-17-2001, 02:13 PM
Matt M38A1
It appears to me that that routing will provide you with the same rotation on all pulleys. I traced it twice. I'm not sure abotut the vibration issue mentioned above. However, excluding that, with good tension that should work.
post #7 of (permalink) Old 05-17-2001, 02:40 PM Thread Starter
kutyafal's Avatar
As Brad said, this routing is supposed to be the same as the TJ routing. I'd like to hope that if it works for the TJ it'd work for a YJ too given the similar engine and pulleys. Good point on the vibration, I'll watch for that. Regarding the push-pull effect I think that given a non-stretching belt and enough tension it shouldn't matter. I think the most important thing is that everything rotates in the right direction as before and that the compressor is aligned (in my case eye-balled [img]/wwwthreads_images/icons/smile.gif[/img]) correctly. I'll play with this tonight and take pictures of any carnage I've suffered. [img]/wwwthreads_images/icons/smile.gif[/img]
kutyafal is offline
post #8 of (permalink) Old 05-17-2001, 07:35 PM Thread Starter
kutyafal's Avatar
Well I've checked it and it looks like there is no interference anywhere with the new routing. The belt I got is too long though since it was meant for the extra loop around the second idler pulley. So off to Pep Boys tomorrow to get a TJ AC belt. I'm keeping my fingers crossed. Root for me. [img]/wwwthreads_images/icons/smile.gif[/img]
kutyafal is offline
post #9 of (permalink) Old 05-17-2001, 11:44 PM
That is the way they are routed on the TJ's and the Grands. The only difference is the diameter of the "existing pully". The new ones use a smaller idler. There is also a change in the mountng of the p/s pump. Now they are fixed to the manifold, and they add a real neat tensioner bearing below. I don't see a problem, in fact, that is the way I have mine routed.
dorfs is offline
post #10 of (permalink) Old 05-18-2001, 12:15 PM
[img]/wwwthreads_images/icons/frown.gif[/img] you might want to makesure your waterpump (or other accessories) is turning the same direction as before you make the changes. I think some of the 4.0L's water pump is different than others (like xj vs yj).
Nycjeep88 [img]/wwwthreads_images/icons/cool.gif[/img][img]/wwwthreads_images/icons/smile.gif[/img][img]/wwwthreads_images/icons/wink.gif[/img]
Let's go baja in NYC and see how well your suspension holds up.... [img]/wwwthreads_images/icons/smile.gif[/img]
