Runs good...wont' idle - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-17-2001, 09:14 AM
Runs good...wont\' idle
I have the 38mm Weber and as of lately, it won't idle at all and backfires on the downshift. I changed nothing in the last two years, but now it runs like crap. Last night I removed the rest of the vacuum lines that were left over from the emissions crap and inspected for vacuum leaks. I really didn't find any and the Jeep ran exactly the same when I was finished.
The surprising thing I found out is that if I hold my hand over the top of the carb with the air cleaner off, it will idle fine. Can anyone give me some advice on this problem. I don't know a lot about carbs.
84 CJ-7/258,Weber 38,Jacob's Omni Mag,flowmaster,3.5" SL,32" BFGMT, Superior 1 piece
post #2 of (permalink) Old 05-17-2001, 10:18 AM
Re: Runs good...wont\' idle
Sounds like symtoms of a vac leak??? Possibly?
post #3 of (permalink) Old 05-17-2001, 10:27 AM
could it be something else. I don't suppose the carb would just up and change its settings without me. I thought it might be something electrical but there really isn't much of a miss.
post #4 of (permalink) Old 05-17-2001, 11:07 AM
I you can cover the carb throat with your hand and the engine does not choke, cough and die... then you've got a MASSIVE vacuum leak. There's no other reason I can think of... Likely it's in the carb to manifold gasket, or the intake manifold to head area. Start spritzing Carb cleaner around the gaskets with the engine running. When the ilde changes, you've found the area of the leak. Just narrow the spray area down and then fix it.
post #5 of (permalink) Old 05-17-2001, 11:13 AM
I don't mean to say that I can totally cover the top of the carb, but I did leave just a very small opening between my fingers in order to keep it idling. Thanks for the tips. I will try to find the vacuum leak when the engine is in fast idle mode. It should stay running long enough for me to track down the problem.
post #6 of (permalink) Old 05-17-2001, 11:38 AM
Are there any vacuum break diaphragms on this carb? I had one go bad on my QJet, and it leaked enough air to make it idle really badly.
Josiah
Hillsboro, OR
1955 Willys CJ5 Buick 225 V6 160HP 270ft-lbs, T90 trans, Warn OD, PTO winch, Spicer 18 T Case, RS9000's, Dana 25F/ 44R,
5.38:1 gears, 11" brakes, Bestop Supertop, Hurculiner
