HELP!!!Removing inner knuckles sans machine shop - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-16-2001, 08:13 PM
I am trying to remove the inner knuckles on a d44. I ground the welds out, and need to get the knuckle off in order to cut the tube down.Not having much luck! The only way I can think to remove the knuckles is to make the cut at the appropriate spot, and press the tube out. Any help would be greatly appreciated....
post #2 of (permalink) Old 05-16-2001, 08:20 PM
Re: HELP!!!Removing inner knuckles sans machine shop
If you're cutting the tube anyway, you can cut it off and use a press or torch to get the remaining tube out of the sub-knuckle. If you're just removing the sub-knuckle it's a bit*h...I ended up slicing the backside with a cut-off wheel and rewelding it, when I changed my caster.
post #3 of (permalink) Old 05-16-2001, 08:48 PM
Immediately after I made the post,I found an article in the tech section which described the process completely.I am going to cut the tubes ,then remove the knuckle.And everybody told me it couldnt be done!!!!!!!!!!!!!!!!
