Scrambler owners, I have a question? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-15-2001, 08:20 PM Thread Starter
TOM85CJ7's Avatar
I need to know about the seat belt mount for shoulder harness belts. My '82 Scrambler doesn't have shoulder belts. I have a set of '85 CJ7 belts I was going to put on the Scrambler. Are they long enough? Can someone give me a detailed description of the mounting point on the roll bar. I would like to copy the factory setup as much as possible. I will fabricate a threaded sleeve that will be welded into the roll bar. How does this setup work with the half hard top? If anyone can give measurements, bolt sizes, picture, etc... That would be great.
Thanks,
Tom
http://home.off-road.com/~tom85cj7/home.htm
TOM85CJ7 is offline
post #2 of (permalink) Old 05-15-2001, 08:48 PM
I Do This For The Glory
JEEPN's Avatar
Re: Scrambler owners, I have a question?
If memory serves, there is a hole in the cab the seat belt attaches to. You have to unbolt it every time you want to take the top off.
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 5" Calmini, Locked, Swamped, Rolled, and just generally broken in right!
JEEPN is offline
post #3 of (permalink) Old 05-15-2001, 08:56 PM Thread Starter
TOM85CJ7's Avatar
Thanks Jeepn, I have that part figured out.
I need to know the straight-line distance from the center of the top of the floor plate to the center of the bolt hole. I also need to know how the bolt/spacer works for the actual mounting of the shoulder strap.
Thanks Again,
TOM85CJ7 is offline
post #4 of (permalink) Old 05-15-2001, 09:07 PM
I will get the details for you tomarrow, it is dark here so i cant measure.
'85 Scrambler
post #5 of (permalink) Old 05-15-2001, 10:30 PM Thread Starter
TOM85CJ7's Avatar
That would be great. I look forward to the info.
Thanks,
TOM85CJ7 is offline
post #6 of (permalink) Old 05-16-2001, 10:48 PM Thread Starter
TOM85CJ7's Avatar
Still need the measurements and description.....
Thanks,
TOM85CJ7 is offline
post #7 of (permalink) Old 05-17-2001, 01:55 PM Thread Starter
TOM85CJ7's Avatar
<<<<<To The Top>>>>>
TOM85CJ7 is offline
post #8 of (permalink) Old 05-17-2001, 04:06 PM
Tom,
Mine is 33 5/8" up from the top of the floor plate to the center of the bolt hole for the shoulder harness.
As far as the way the shoulder harness attaches, it is with a bolt that threads into the bung that is welded into the roll bar. There is a rubber bushing or spacer (mine is 1 1/4" long compressed) that spaces the shoulder harness away from the roll bar. I assume that is so the half cab fits somewhere in the middle of the bushing. Also there is a washer between the shoulder harness and the rubber bushing.
Also, I don't think it will matter, but the two roll bar designs are slightly different (besides the shoulder harness mounting bung). The hoop is the same, it's just the later versions came down further before angling toward the base plate. The straight part of the hoop coming down goes about 2" below the top of the tub before angling toward the base plate. The base plate appears to be in the same spot in relation to the hoop, it's just the bars with shoulder belts has a slightly sharper angle. The hoops without the shoulder harness start to angle toward the base plate about 3" above the top of the tub. If it matters, there you have it. If not, ignore this last paragraph.
-raymo
4.6 Stroker Scrambler
raymo is offline
