Starter Problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-14-2001, 09:46 AM
Starter Problem
It seems as if my Jeep is frying starters. They only last about 2 weeks before all they will do is go click. What do you think is wrong? Thanks in advance. This does not make since but it seems to have started this around the time I installed my winch. The Winch.
1990 Wrangler YJ 4.2 6 cylinder 5 speed manual trans, 4 inch pro-comp lift, JKS quick disconnects, 32X11.50 Mud Kings, Warn xd9000i winch.
post #2 of (permalink) Old 05-14-2001, 10:49 AM
Re: Starter Problem
sounds like a bad connection somewhere, positive or ground cable.
post #3 of (permalink) Old 05-14-2001, 01:52 PM
Re: Starter Problem
Definitely sounds like bad wiring. Do you have a starter kill alarm? A lot of times the wiring they use is crap. I had a bad ground and all the starter would do was click once and then nothing. I had the alarm completely re-wired and presto, no more probs. Hope this helps. - Andy
'94 YJ - 4.0, 5" Suspension/Shackle lift, 33" Muds
post #4 of (permalink) Old 05-14-2001, 02:08 PM
Re: Starter Problem
I did have an alarm with a starter kill. I took it out totaly though. I replaced the factory starter about a month ago the replacement started doin the same thing a couple of weeks later. I replaced the starter again & pulled the alarm out totally the same day thinking there may be a short causing the problem. Now a couple of weeks later the same problem is back again.
