Where to get body mount material - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-12-2001, 10:19 PM
Does anyone know where to buy polyurethane body mouting material that can be cut to the desired length. 4WD Hardware sells rubber in 24" lengths, but I really want something that will last. I have a fiberglass tub so the precut kits won't work. Thanks.
post #2 of (permalink) Old 05-13-2001, 06:36 AM
Re: Where to get body mount material
FWIW, (for what it's worth)...I thought you shouldn't use poly for a fiber tub. Somthing about poly won't flex much causing tub to crack????
JimmyZ is offline
post #3 of (permalink) Old 05-13-2001, 07:50 AM
jeepfreak1
I purchased an AJ,s body and was told that it should not be a problem,
then again if you think about it,the way most everyone ties their roll cages into the frame the soft cushy bushings are worthless.(4wdhwd,s system)
I am in process of making a mounting system to use factory bushings on my new body.
so I guess ill find out first hand
<font color=green> JF1 </font color=green>
post #4 of (permalink) Old 05-13-2001, 08:50 AM
Dean
You might try some of the boat supply stores to see if they have boat trailer rollers in poly. I bought rubber ones from West Marine to make bushings for my roll cage tie-in mounts. It's very hard rubber with very little, if any, give to it; it's probably as hard as poly and holds up well. FWIW, I have an AJ's Deluxe body and front end, and I used their pre-cut rubber bushings (~.5" thick that I stacked to fit) to mount the body. AJ's bushings are fabric re-inforced and are not spongy like regular rubber. I've had them in for ~4 years now and they've held up very well to both the TX heat and the salt and sand of SFL.
Dean
Dean
