AMC 20 Question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-12-2001, 04:21 PM Thread Starter
Caver Dave's Avatar
AMC 20 Question
My brothers '86 CJ7 had a bearing go out (cage gone, rollers loose)in his model 20. They pulled the flange w/ axle "attached" to fix the bearing.
The problem is that after 4 hours of banging, penetrating oil, a torch, and a 25TON press, we can't get the [email protected] axle out of the flange. Are we completely retarded and missing something? Could the axle have "stripped" and spun/twisted in the flange, in essense locking it? The little bit of splines I see don't look deformed or twisted.
We sure could use some ideas on this one! Does anyone have any "tricks" for removing the flanges they could share? TIA!
Caver Dave
'68 Jeepster Wagon
225, 3spd, & road salt A/C
Vintage Jeeps(ters) have Character,
new Jeeps just have payments.
Caver Dave is offline
post #2 of (permalink) Old 05-12-2001, 05:24 PM
pontiac58's Avatar
Re: AMC 20 Question
Put it back in the press and put some a$$ on it. Use a piece of pipe on the handle to get farther away from it. When it goes look out. If you have to, leave it there with pressure on it overnight.
Can someone please bring me a hammer my 33's just ate my fender again. Damn i need more lift.
pontiac58 is offline
post #3 of (permalink) Old 05-12-2001, 05:59 PM
Re: AMC 20 Question
maybe a good time to goto a 1 pc kit.
im sure it will come off if given the proper heat/tonnage.
but will it ever hold that well again?
OzarkJeep
"Bare foot girls, dancing in the moon light..."
ozarkjeep is offline
post #4 of (permalink) Old 05-12-2001, 10:13 PM Thread Starter
Caver Dave's Avatar
Re: More AMC 20 Question
Also, My bro says this flange is/was brand new about 1+ year ago. He says that it was smooth and the splines(in the flange) were cut when he torqued the axle nut down. Is this right or has he put the wrong flange in? (I personally don't like m20 and don't know anything about wrenching on them)
He said this swap was done in Jan. when the temp was 20* outside. Is it possible the axle "shrank" from the cold, the splines were cut on a warm flange, and created the mother of all press fits? We lost access to the press this weekend, but will try more oil & BAP (big a$$ puller) over night to see if this helps.
I mentioned the one piece axles, but he doesn't understand what they'll do for him, other than make the 2 parts 1. Any info & experiences I can pass on to him?
Caver Dave
'68 Jeepster Wagon
post #5 of (permalink) Old 05-12-2001, 10:44 PM
Those 2 pieces you are finding impossible to separate, well they will spin on each other at a very bad time, leaving you stranded. This is a semi-floating, not full-floating axle, once it spins, you are sunk. And those M20 break parts, they aren't cheap and they are hard to find, and chances are they may be damaged (ie: backing plate).
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
post #6 of (permalink) Old 05-13-2001, 08:28 AM
The new hubs are smooth and the axle cuts into it during assembly. Some complain about the axles being weak but I've never had one break and never run anything less than a 304.
lindy80cj7 is offline
post #7 of (permalink) Old 05-13-2001, 10:10 AM
I've never had my M20 spin a hub either and I have a 304 backed by the gearing of a T18a...though I have broken an axle shaft in there[img]/wwwthreads_images/icons/wink.gif[/img].
Fritz
Jeep...need I say more?
ExtinctJeep is offline
