brakes..broke - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-10-2001, 11:47 AM Thread Starter
brakes..broke
when i hit the brakes the jeep pulls right. so i replaced both front calipers and pads but it still pulls. i know it is def. the front right b/c on gravel or wet roads, that one locks up. i have bled and re-bled that line, but no good. the only thing i can figure is that the replacement was bad too and need replaced. any other suggestions? could rotten rubber brake lines do this?
thanks all,
shawn
The cup isn't half full or half empty, it's just twice the size it needs to be!!!
80cj is offline
post #2 of (permalink) Old 05-10-2001, 01:54 PM
Re: brakes..broke
A bad rubber brake hose could possibly produce the symptoms you mentioned. However, the one thing that is jumping to mind is a possible warped rotor. Might be something to look into.
--Digger--
http://www.users.qwest.net/~ascanlon
post #3 of (permalink) Old 05-10-2001, 02:32 PM Thread Starter
Re: brakes..broke
Already replaced the rotors and if it was the a warped rotor the pedal would probably have a shimmy to it
80cj is offline
post #4 of (permalink) Old 05-10-2001, 02:59 PM
Re: brakes..broke
You might have a collapse brake hose or bad brake proportion valve.
Nycjeep88 [img]/wwwthreads_images/icons/cool.gif[/img][img]/wwwthreads_images/icons/smile.gif[/img][img]/wwwthreads_images/icons/wink.gif[/img]
Wanna go baja in NYC and see how well your suspension holds up [img]/wwwthreads_images/icons/smile.gif[/img] !!
post #5 of (permalink) Old 05-10-2001, 03:07 PM Thread Starter
Re: brakes..broke
is there any way to trouble shoot that besides just replacing them?
shawn
80cj is offline
post #6 of (permalink) Old 05-10-2001, 03:08 PM
Re: brakes..broke
When was your jeep last alined?
post #7 of (permalink) Old 05-10-2001, 03:14 PM
Re: brakes..broke
On brake parts! I don't think so [img]/wwwthreads_images/icons/blush.gif[/img]. Correct me if I'm wrong, anyone?
Nycjeep88 [img]/wwwthreads_images/icons/smile.gif[/img][img]/wwwthreads_images/icons/cool.gif[/img][img]/wwwthreads_images/icons/wink.gif[/img]
Let go baja in NYC and see how well your suspension holds up.... [img]/wwwthreads_images/icons/smile.gif[/img]
post #8 of (permalink) Old 05-10-2001, 03:40 PM Thread Starter
Re: brakes..broke
aligned? what's that? to answer your question...not since i bought it a year and a half ago. how would alignment cause that brake to lock up?
shawn
80cj is offline
post #9 of (permalink) Old 05-10-2001, 03:52 PM
Re: brakes..broke
Maybe your left brake isn't working very well? In a stock brake system on gravel the front brakes should lock up before the rears, because when you brake hard on pavement your jeep's weight will shift forward and the front brakes will do most of the work, and you don't want your rear brakes locking up on you. So don't ignore the left side; your right brake may be working perfectly.
Regards,
Josiah
Hillsboro, OR
1955 Willys CJ5 Buick 225 V6 160HP 270ft-lbs, T90 trans, Warn OD, PTO winch, Spicer 18 T Case, RS9000's, Dana 25F/ 44R,
5.38:1 gears, 11" brakes, Bestop Supertop, Hurculiner
post #10 of (permalink) Old 05-10-2001, 05:48 PM
Re: brakes..broke
i am thinking along the lines of 55cj5. sounds to me like your right is working and your left is on a holiday. when you get on the binders and it pulls to the right, does it continue to pull after you let off? if not, then your right is working and your left side is resting. if it continues to pull after you release the pedal, then the right side is sticking. did it get this way all of a sudden, or has it been gradually getting worse, or did it just come out from a long winters nap?
J ust
E mpty
E very
P ocket
yjdave is offline
