York-radiator hose clearance - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-29-2001, 08:32 PM
I'm putting a York on my '82 CJ-7 with 4.2 for onboard air. Has anyone had the same problem as me with the radiator hose hitting the pulley? Was there a different hose for use with air conditioning?
post #2 of (permalink) Old 03-29-2001, 08:39 PM
Re: York-radiator hose clearance
what did your YORK come from? the FORD truck versions Ive seen have HUGE pulleys, much larger diameter than any york Jeep application.
otherwise im at a loss
OzarkJeep
"If thats the way that you want it, well thats the way I want it more..."
ozarkjeep is offline
post #3 of (permalink) Old 03-30-2001, 05:05 AM
Sorry, I forgot to put that in. It's off a mid '80s Volvo. I read somewhere that they were supposed to have smaller diameter pulleys than others. It's got a 6" diameter. Is there one with a smaller pulley I could get?
Darren
post #4 of (permalink) Old 03-30-2001, 07:01 AM
There is a different upper radiator hose for a CJ with air conditioning
done is offline
post #5 of (permalink) Old 03-30-2001, 08:18 AM
I added a york OBA system to my 74 CJ-5 and added a thermostat cover from a 4.0. It is angled back towards the firewall and adds sufficient clearance for the belt. Fits with no problem and is cheap. It is aluminum, hope this helps.
post #6 of (permalink) Old 03-30-2001, 10:14 AM
I had the same problem. I tried the hose for CJ's with air and it helped, but not enough. I ended up taking a couple of hoses from the parts store and grafting them together. The counter guy let me wander around behind the counter to pick whichever hose I wanted. Problem is I can't remember the applications, so if something blows I'm SOL.
'75 CJ5,258 w/Howell EFI,T18a,4.27's,33's,On-board air,Warn 8274
post #7 of (permalink) Old 03-30-2001, 04:49 PM
I had the same problem, solved it in a totally different manner. Since I built the mount for the york, I just built a protective cover over the pulley. I then added a cover or "wear" surface on the hose. It should work for a long time.
Enjoying Montana's Big Sky & Snow(Skiing that is)
jfralph is offline
post #8 of (permalink) Old 03-30-2001, 04:55 PM
Here's the answer to all your problems, so listen carefully!
I did the York route in my 84 CJ-7 last summer, and also had radiator hose clearance issues.
I tried a couple of different hoses, trimmed all different ways, but never got enough clearance. After thinking about it, and staring at the engine bay for a while, I came upon the solution. Raise the radiator in the grill! There was already mounting holes in my grill for it, all I had to do was move the nutplates up. It got moved up about an inch, and made all the difference in the world.
Bob in Ma
Bob Ackley is offline
post #9 of (permalink) Old 03-30-2001, 09:48 PM
I appreciate all of your responses. Went out and checked my radiator, and it's already up on the top set of holes. I think I'll try the hose for air conditioned models and see if that helps before I get too creative.
One more question. Does anyone know where I can find a pressure switch for under $40? That's all I've seen, but I seem to recall several web sites that state you can get one for $18 to $20. Am I hoping for too much on that, or are they around for that price?
Thanks again,
Darren
post #10 of (permalink) Old 03-31-2001, 07:41 AM
http://www.rubiconexpress.com/sun/accessories.html sells the style that I use. I tried to keep my OBA project compact and tidy, and those huge Square D switches are monsters! Not to mention the fact that you don't need an unloader with the engine driven compressors. I looked all over for small switches, and these work well. I got the #PS001 Quick Air 1 style , and I think it's about $20.
Bob in Ma
