drive shaft problems - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-26-2001, 04:48 PM
just put in a 4 inch superlift on my wifes 98 tj after installing the lift got vibration and once in a while the whole jeep would shake and the shifter would slam back and forth side to side any suggestions.
post #2 of (permalink) Old 03-26-2001, 05:05 PM
Re: drive shaft problems
Yes you do have a problem there. You need a S.Y.E. installed. Did you lower your t/case? If you haven't I would start there.
Top Dawg!! Only the Big Dawgs Bark!!
post #3 of (permalink) Old 03-26-2001, 05:08 PM
Official Historian
WILL's Avatar
Did you lower the skidplate? Did you install a SYE kit and a longer driveshaft? That's what will get rid of the vibration. Your u-joints might be operating at too much angle.
The other possibility is that your u-joints are not operating at the same angle. Get a protractor and measure the angle of the transfer case output and compare it to the pinion angle. The pinion should be between 0 and 2 degrees down from the transfer case.
79/CJ-7/AMC360/TH400/Q-TRAC/d30/d44/33's/RS9000s/Herculiner/Pro-jection 2D/MSD/4.10s/lockrights
WILL is offline
post #4 of (permalink) Old 03-26-2001, 05:21 PM
yes i lowered the transfer case it came with cam bolts to adjust the angle in the back noticed today that the guy who put them in stripped them got new ones comming having the shop put them in will i damage anything driving it there if i drive slow its about 30 miles
post #5 of (permalink) Old 03-26-2001, 05:32 PM
You could take out the seal in the back of the t/case if it's that bad. Try to get it fixed as fast as possible!
