electrical problem in CJ - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-26-2001, 11:17 AM
Ok heres the situation...I replaced the wiring harness in my project CJ with a new one from centech. After much trial and error, mainly error I have everything working except for the fuel gauge. I was doing some testing last weekend and found that I have a good ground to the guage, as well as continuity from the sending unit to the gauge...so I figured that it had to be a bad gauge? Does this seem correct or not? One other thing, before I determined that the ground was good I disconnected the ground from the gauge and ran it straight to the battery ground. Upon doing this I blew a fuse and have no idea why???
Dan
post #2 of (permalink) Old 03-26-2001, 11:48 AM
Re: electrical problem in CJ
Dan-
In the first place, the fuel gauge does not have a 'ground' terminal.
It grounds via the speedo housing. Probably you not only blew a fuse but also cooked your gauges ...
Read my article (twice), preform the resistance tests on both the fuel and temp gauges to see if they might still be good get back to me if you need help or suggetions ...
Click ... http://www.monsterslayer.com/jeep/Gauges.htm
JAF
Jaffer is offline
post #3 of (permalink) Old 03-26-2001, 12:46 PM
Thanks for the info, I actually already read your page about the gauges...How could I have fried my gauges? I just assumed that if I hooked it directly to ground than it would be no different, I thought a ground was a ground and the way the voltage was regulated was through the power lead? Is this correct or not? Anyway, if I have ground at the gauge as well as the sending unit wire, shouldn't the gauge work unless its a bad gauge? I tried to short it out like your page indicates and I only got it to move to like 1/2 full once. I'm not sure if I was doing it right however, so I should probably do it again when I get a chance...Any other suggestions? I really don't want to get the SW gauges because they are $80 for the fuel and temp, and I am not even using the temp because I have a mechanical temp and oil gauge. What are the chances of getting a used gauge that works? Is burning up the gauge common?
Dan
post #4 of (permalink) Old 03-26-2001, 01:49 PM
Dan-
I was guessing you were mistaking a sender or Batt+ terminal for a ground terminal.
I still can't figger out how you shorted unless you ran the ground from the Batt- to the "I" (ignition on) terminal.
If you can still get the gauge to read by shorting the gauge's sender wire to ground, then the gauge may still be OK.
You must do the resistance tests to all the fuel gauge's posts to confirm the gauge is still good.
Let me know.
John
JAF
Jaffer is offline
post #5 of (permalink) Old 03-27-2001, 07:33 AM
Do you have a good ground on your sending unit?
Mark
83 CJ-7 and 76 CJ-7 with stuff
sloop is offline
