lock right installation - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-25-2001, 06:08 PM Thread Starter
Novice
Iam trying to install a lock right in a dana 44 from a 72 cj5 but I can not figure out why the cross shaft that I bought with the locker will not stay in place. If this thing moves around in there it will wind up hitting the pinion gear.
snatch1 is offline
post #2 of (permalink) Old 03-25-2001, 06:47 PM
Re: lock right installation
Did you put the retaining pin back in?? When you do that, that cross shaft doesn't move more than about 1/16 of an inch!
'77 CJ5, D30, 304,T-150,D20,FullFloat+Locked AMC 20, 4" BDS, 35x12.50 15 BFG MT's
Building an AMC 360
post #3 of (permalink) Old 03-25-2001, 07:09 PM Thread Starter
Novice
when I took out the old cross shaft there was 2 hard small clips that fit into groves on the cross shaft, now the new cross shaft has 4 flat spaces, 2 on each side with no groves for the clips to fit in. I tried to put them back on but they just pop out. The new cross shaft was clearly marked dana 44
snatch1 is offline
post #4 of (permalink) Old 03-25-2001, 07:19 PM
It sounds like you are missing a piece or have the wrong piece.
Does the new cross shaft have a hole through it at one end? If so, there should be either a roll-pin that presses (taps in with a punch) through the carrier and through that hole or there should be a small retaining bolt that goes through the carrier and cross shaft.
If the new shaft doesn't have a hole, then you probably need one just like the one that came out. That is what I would guess.
-raymo
Scrambler
258 4.0 Head/MPI,NV4500,D300,4.10's,HS9500
raymo is offline
post #5 of (permalink) Old 03-25-2001, 08:21 PM
Official Historian
WILL's Avatar
Another option if the wrong cross shaft got sent to you is to reuse the stock cross shaft. My lockright didn't come with a cross shaft, I'm just using a stock cross shaft in the carrier.
79/CJ-7/AMC360/TH400/Q-TRAC/d30/d44/33's/RS9000s/Herculiner/Pro-jection 2D/MSD/4.10s/lockrights
WILL is offline
post #6 of (permalink) Old 03-25-2001, 08:39 PM Thread Starter
Novice
I looked at the carrier & it don't have a hole to put any kind of pin through
snatch1 is offline
post #7 of (permalink) Old 03-25-2001, 11:46 PM
If it were my Jeep, I would put the stock one back in to get back on the road, but I would find out if the locker was supposed to come with the stronger version, and if so, get it and replace it later.
If there is not a hole for a cross pin, then the retaining clips are there to do their job.
-raymo
Scrambler
raymo is offline
post #8 of (permalink) Old 03-26-2001, 08:02 AM
Mel85CJ's Avatar
Some lock rights dont come with the "hardened cross shafts" - depends on where you buy it from - I have a buddy who is running a '75 CJ5 with a D44 & lock-rite in the rear with the original cross-shaft, its been about 3 years & a decent amount of Jeepin' & no problems.
-Mel
Mel85CJ is offline
