Auto Trans Line Material - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-25-2001, 01:54 PM
I'm replacing the rubber(?) line from my radiator to the tranny. What kind if line do you use for auto trannys? Will regular rubber fuel line work? If not, is the fluid not compatible with the rubber or is it the pressure?
Thanks,
John
post #2 of (permalink) Old 03-25-2001, 06:12 PM
Dirt Dog's Avatar
Re: Auto Trans Line Material
Do not use regular fuel line for this. They make a rubber trans hose. It is about twice as thick as fuel line and holds up forever. I woild recomend steel lines out of the trans to as close as you can get to the cooler. Then run the rubber lines.
http://home1.gte.net/rythem/davescj7.htm
Dirt Dog is offline
post #3 of (permalink) Old 03-25-2001, 08:14 PM
1. Fill out your profile, it helps to get an accurate answer.
2. Use replacement brake line sections and a flaring tool. Cheap, easy, and done. You should be ablt to go from the AT to the Cooler with solid line on a OEM radiator.
post #4 of (permalink) Old 03-25-2001, 08:39 PM
1. Profile updated.
2. Thanks, but can you get 3/8ths in. ID brake line?
John
85CJ7, 258-six, auto, 4" Skyjacker lift, 4:10 gears with rear Detroit Softlocker, B&M Megashifter, 32x11.50 generics(Swampers soon), MSD ignition.
post #5 of (permalink) Old 03-25-2001, 08:46 PM
Yes...
post #6 of (permalink) Old 03-25-2001, 09:15 PM
Official Historian
WILL's Avatar
I bought replacement lines that screw into the radiator and into the hard lines running from the transmission. Is your auto swapped in or stock?
79/CJ-7/AMC360/TH400/Q-TRAC/d30/d44/33's/RS9000s/Herculiner/Pro-jection 2D/MSD/4.10s/lockrights
WILL is offline
post #7 of (permalink) Old 03-25-2001, 09:31 PM
I have a OEM TF999 that I just rebuilt. I ran new cooler lines using the brake line material.
post #8 of (permalink) Old 03-26-2001, 09:04 PM
Thanks for the info. My 999 is stock.
John
post #9 of (permalink) Old 03-26-2001, 09:10 PM
I bought prebent stainless. I think they were from Classic Tube. Rust is a problem here and I wanted to only fix
them once.
