GAS TANK SKIDZ - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-28-2000, 11:47 AM Thread Starter
GAS TANK SKIDZ
Who makes a heavy duty gas tank skid plate? I looked in 4wd' and some other catalogs, but they all look flimsy. I was wanting something 1/4" thick. The aluminum daimond plate is too soft. Any ideas?
Lugnut 77' CJ5
lugnut is offline
post #2 of (permalink) Old 03-29-2000, 02:37 AM
Re: GAS TANK SKIDZ
Check out www.fourxdoctor.com, they have one for the 20 gal tank.
Mike.
Mike Duncan
[email protected]
post #3 of (permalink) Old 03-29-2000, 07:50 AM
Re: GAS TANK SKIDZ
I am going to make one out of some 3/16" steel diamond plate, fairly cheap stuff. May take a press to bend though.
<font color=red>'88 YJ, 4" susp,3" body,33's,283 Chevy V8,TH350,4.11's,D30,D35c</font color=red>
v8jeep is offline
post #4 of (permalink) Old 03-29-2000, 08:21 AM
Re: GAS TANK SKIDZ
I have the Tomken and wouldn't recommend it because of it's attachment method. It use two brackets on the back half that bolt up into the frame ends where the stock bumper bolts go in. I had to remove the tank skid to install a new bumper and snapped both bolts off trying to remove them. I think the brackets stick out too far and when you come down off of a ledge they smack and the bolts get bent. I also don't like the finish on it. The 4xdoctor one uses the stock holes and maintains clearance. I would either go with the 4xdoctor one or Tera Flex's.
Good luck,
Aaron
post #5 of (permalink) Old 03-29-2000, 12:32 PM
Re: GAS TANK SKIDZ
In regard to bending the steel diamond plate, here's the preferred farmer technique.
1. Position steel on top of a very sturdy steel structure (welding table, welding stands, etc.) so that the line where you desire the bend to be at is just under 1/4" away from the edge of the table (so the desired bend will be just a hair past the table.
2. Take a big piece of angle iron and place it on top of the piece of steel, so that it is even with the edge of the table...use a few big c-clamps or those screw/friction welding clamps to really crank that baby down to the table.
3. Get out your rosebud torch end, and have a sledge hammer handy.
4. Before bending, make a little jig out of wood or light steel that shows the angle you want to bend to.
5. Use the rosebud to heat one corner red hot...as it gets hot, slowly move across the bend line from side to side, building heat...as you move across, that which has already been heated will start to cool, so you have to heat a little, then backtrack, then heat a little more. When you have the whole thing pretty darn hot right at your bend, start smacking it with the sledge...use your jig to measure the proper angle. It helps to have a buddy run the sledge so you can measure with the jig and keep heating with the torch.
Just a side note...when I built mine, I wasn't nearly as worried about the skid being dented or pushed up into the jeep (since it was heavy steel and was attached pretty darn securely) as I was about the front lip being caught on something and pushed backwards. There's not a very good way to attach it in the front that I felt wholly comfortable with, so I built a crossmember that ties the rear of the skidplate into the rear frame crossmember and my h/d rear bumper to keep the skidplate from relocating the gas tank to the rear a few inches...might want to think about that...
Trying to come up with a witty line to end all of my posts...
post #6 of (permalink) Old 03-29-2000, 01:13 PM
Re: GAS TANK SKIDZ
I have the Tomken on my TJ. Haven't had to remove it so don't know if the bolts are good or not, but it has been banged around a bunch and has held up well.
Would not suggest diamond plate for one reason - it isn't smooth and doesn't slide on rocks and such as easily as smooth steel would. Absolutely would NOT use aluminum. 3/16" steel is fine, quarter might be a bit much, but still ok.
Doug '97 TJ
Creator of the CBrack
CBrack.com
