-   -   Transfer case shifter with body lift (https://forums.off-road.com/jeep-short-wheelbase/62836-transfer-case-shifter-body-lift.html)
Frank79CJ 03-24-2001 11:38 AM
My transfer case shifter will not go into 4 high because of the 3" body lift. The angle is to great. It goes into low but the plate has been cut out to allow it. It currently has no boots just open to the ground. What options do I have to correct this, without having to cut the floor open and fabricate something?
79 CJ7/33's/304/3-speed
3jeepguy 03-24-2001 12:21 PM
Re: Transfer case shifter with body lift
you have too open up the hole a bit or take the shift rod out and heat it and bend it up a little to get the clearance if you open the hole up just get a bigger shift boot for it
jeep the first 4 wheel drive the only 4 wheel drive
**DONOTDELETE** 03-24-2001 01:15 PM
Junkyards are full of nice shifter boots, $5 max.
Dirt Dog 03-24-2001 06:13 PM
You'll have to open the hole up some. The problem is that since your up higher on the shifter, the throw is longer. Yiu can bend the handle all you want........you'll still have to cut the floor. I had to even on my 2".
http://bbs.off-road.com/wwwthreads_u...95-jeepsig.jpg
http://home1.gte.net/rythem/davescj7.htm
Frank79CJ 03-24-2001 07:26 PM
That's what I figured. I was hoping that there was a trick I didn't know about that would work.
