lift kit - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-22-2001, 02:52 PM
81cj5
lift kit
Going to install 4" lif kit on my 81 cj5. i dont know much at all. what is the best way to do it? also what to take into consideration? brake lines? whatr else?
post #2 of (permalink) Old 03-22-2001, 05:34 PM
Re: lift kit
To do a good 4" lift you need a fair amount of parts
-4" lift springs
-All new u-bolts (unless your's are in really good shape)
-Drop pit man arm
-Spring eye bushings
-Extended bump stops
-Either a t-case lowering kit and degree shims or a new longer rear drive shaft, might have to be a cv shaft because of angles, maybe a front one too
-longer break lines all around
-Extended shock and maybe a new steering stablizer
-Sway bar extensions or extended disconects
-Beefe shackles are a good idea, the stock ones are week
-Also putting heavy duty spring mounts and frame reinforcement plates are good ideas if you push your jeep hard.
-Also if you have your stock d30/m20 axles and plan on running 33's or 35's you should swap out the d30 and either add 1 pieces and a truss or swap out the m20 for d44's or 60's, I wouldn't stress your stock drivetrain that hard and would do the swap before you get the lift and tires
-Oh yeah unless you have 15x8 or 15x10 wheels you will probably need new wheels to put the tires on.
Barrelroll
97 TJ 30" ko's stock but not for long
Jeeper99xj is offline
