rear shock mount - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-27-2000, 09:20 AM
rear shock mount
Help the rear upper shock mount on my '85 CJ-7 has sheared. Does anyone know of a good fix or where I can get replacement parts? It is just the threaded pin that needs to be replaced. Thaks for any help.
'78 CJ7 304, rust, inspected![img]/wwwthreads_images/icons/crazy.gif[/img]
post #2 of (permalink) Old 03-27-2000, 09:35 AM
Re: rear shock mount
Sounds like a good time to do a U-bolt reversal. However, it will require that you weld on a shock mount bracket. Confer makes them. If you do regular off roading, you will be glad for the extra ground clearance.
If you don't want to go that route then you can go to a junk yard and get another plate. You can also get the parts from Savana Jones.
John......southern CA
84CJ7, 3"lift, 32"BFG, 4.10's, ARB Locker, Solid Axle's, Durabak
post #3 of (permalink) Old 03-27-2000, 12:00 PM
Dana's Avatar
If only the treaded portion is gone, but the main post is still there..... well..... about a year ago I noticed the same problem with my CJ5. I used some soft copper wire to hold the shock on long enough to get home. I'll fix it right one of these days.....
-Dana
Press any key... no, no, no, NOT THAT ONE!
Dana is offline
post #4 of (permalink) Old 03-27-2000, 03:50 PM
I am refering to the end that mounts to the frame not the axle. I need a permenant fix for this.
post #5 of (permalink) Old 03-27-2000, 07:56 PM
Dana's Avatar
OK, if you can drill and/or grind out what's left of the old one, you can buy replacement posts for it, I looked at one..... but since my copper wire fix was still holding, I figured why spend the money? [img]/wwwthreads_images/icons/smile.gif[/img][img]/wwwthreads_images/icons/smile.gif[/img]
-Dana
Mary had a little lamb. The doctor was very surprised.
Dana is offline
