Re: Help! need to know bolt patterns!
Don't just check the bolt holes, check the hub opening as well. The newer Ford/Dodge that were 5 on 5 1/2 had the smaller hub opening. Most of the aftermarket wheels have the larger hub opening. Don't plan on using stock wheels off of these rigs unless you plan on opening up that hub hole. My spare is on an 87 Dodge wheel and I had to open it up using my dremel so that it would fit over my hubs. If you open a stock wheel up too much, that's no big deal because none of the 5 on 5 1/2 or 5 on 4 1/2 wheels (that I know of) were ever hub-centric (meaning they were centered via the hub opening). I've only seen lug-centric (yes this means they are centered via the lug's)....Bret
'56 CJ-5, 283, t-90/d18, 25/44, 32's on 15x10's,no lift yet, cage.
