Herculiner/Durabak Question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-21-2001, 12:09 PM Thread Starter
The Canadian version of these products is GatorGuard but I assume the instructions are similar. I want to get my tub done NOW , I think it better be done outside (fumes and all) . The directions say apply when the temp is 70 deg F or above . Where I live that may be MAY . Just was curious if any of you have put that in your tubs when the temp was cooler ? How did it look ? How was the finished product ? Thanks a bunch for any help
Jeff
<font color=black>Spring is just around the corner [img]/wwwthreads_images/icons/tongue.gif[/img] </font color=black>
Jeepzilla is offline
post #2 of (permalink) Old 03-21-2001, 01:00 PM
ibscrmbln
Re: Herculiner/Durabak Question
I did Durabak to my CJ8 a little over two years ago and it still looks pretty good. I did it in black. I also did it in the winter but in a heated barn where I tried to keep it up to around 50 degrees for 2 or 3 days until it had totally cured. The fumes are strong but it is only for a couple of hours. I do remember needing to take a fresh air break between coats.
There are now a couple of spots on the tailgate where the material has been dislodged but other than that it still looks pretty good after washing up. It does get a little tacky looking when dusty.
Later, Ken.
83 CJ8, 4.0 HO/AW4, 2.5 Superlift, 1" Daystar body, 33x12.50 GY MTs, 4.10, Lockers front & rear, on-board air, Durabak cab and bed, Trailquest tank, lots of small stuff.
post #3 of (permalink) Old 03-21-2001, 01:07 PM Thread Starter
That`s something I never thought of , that stuff being somewhat "gritty" it must be a real dust catcher [img]/wwwthreads_images/icons/smile.gif[/img]
Well if you did it when it was 50 deg then I should be fine .How much time do you have before the batch you make up becomes hard ? 15 mintues , 30 minutes ? Thanks dude !
Jeff
post #4 of (permalink) Old 03-21-2001, 05:13 PM
sas87yj
zilla-
yeah 70 degrees is not mandatory. i would think it is preferred but 50 , 60 would work. i waited say 1 hour between coats- don't exactly remember but it was a longer wait than the instructions said. you have to wait till the coat gets somewhat dry. you'll figure it out. i did mine in the garage- it's a cheap high![img]/wwwthreads_images/icons/smile.gif[/img]
steve
post #5 of (permalink) Old 03-21-2001, 05:15 PM
On a related note- How hot can you get the stuff? Is it good for under body coating? Near the engine in the engine compartment?
post #6 of (permalink) Old 03-21-2001, 05:36 PM
sas87yj
kurth-
oh yeah- undercoat and engine compartment would be fine. don't know how hot you can get it but underneath doesn't get too hot and the engine compartment would be no prob. i wouldn't hesitate.
steve
post #7 of (permalink) Old 03-21-2001, 07:09 PM
jps4ever's Avatar
I put Durabak in my jeep last year and the cooler air did not seem to do anything to it. Stunk like hell for days. After one summer in the sun it has already started to fade a little. And yes, it does get dusty and looks crappy. It takes me an hour with a water hose and brush to get most dirt/mud out the drain holes. The dirt just settles in and it's very hard to wash it out. I had dreams of just getting the hose out and being done in about 5 min. Yeah, right...
A fool and his money are soon partying.
jps4ever is offline
post #8 of (permalink) Old 03-22-2001, 01:34 PM
ibscrmbln
My time between coats were like the others, an hour or two.
In terms of heat, it will take a lot. I installed a Flowmaster under the drivers seat after the 4.0 swap. It melted the carpet in spots where there was weight on it before I realized how hot the floor was. Built a two layer baffle over the Flowmaster below the floor to fix. Never fazed the Durabak.
Later, Ken.
83 CJ8, 4.0 HO/AW4, 2.5 Superlift, 1" Daystar body, 33x12.50 GY MTs, 4.10, Lockers front & rear, on-board air, Custom bumpers, rockers, and skid plate,Trailquest tank, lots of small stuff.
post #9 of (permalink) Old 03-22-2001, 02:16 PM
DannyL's Avatar
It would seem that Canadian Tire does not sell it any more. They have replaced it with something called HippoLiner and sells for $50 a half gallon. I don't know where else you can get the GatorGuard or if it's the same product....
DannyL
Pony Express
http://www.partszuki.homestead.com
DannyL is offline
post #10 of (permalink) Old 03-22-2001, 05:30 PM
Is there any way to filter out most other rubber 'grit' from the Herculiner before installing, so its a a little smoother?
Smoother so it cleans up easier, but still has some grit for traction.
Maybe don't stir it up too much.
Is the stiring before apply to get the rubber suspended back in the liquid, or does the liquid part also seperate some(like oil based paint).?
