ring gear set up question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-24-2000, 06:08 PM
Im finishing the assembly of a ring/pinion in a scout d44 that is going in the front of my 89 wrangler. Question is: jeep service manual states that new pinion bearings require 20-40 inch pounds of preload torque. Whereas randy's ring and pinion installation manual sites 14-19 inch pounds. It is a dana gear set. And, my tourque wrench only goes down to 20 inch pounds. Who is right? TIA,jamey williams
post #2 of (permalink) Old 03-24-2000, 06:53 PM
DRM
Re: ring gear set up question
If I remember right, you are testing the rotational drag on the pinion when set up, correct?
If so, just set yours to 20 in/lb and you should be ok...
<a href="http://www.tennessee4x4.com/toyota">
DRM is offline
post #3 of (permalink) Old 03-24-2000, 08:38 PM
yes that is the rotational drag. thanks for the help. jamey
post #4 of (permalink) Old 03-24-2000, 10:12 PM
TOM85CJ7's Avatar
I found differing info on this also. Most axles require 20 in/lbs of pinion bearing preload for new bearings and 6-10 in/lbs for used bearings.
Tom
<font color=green>85 CJ7-4.2L,T-176,D300,2.5"lift,32"BFG MT,Durabak,York-Air,HEI</font color=green>
TOM85CJ7 is offline
