-   -   Tranny Swap (https://forums.off-road.com/jeep-short-wheelbase/6146-tranny-swap.html)
**DONOTDELETE** 03-23-2000 11:46 PM
Tranny Swap
Have some questions on which tranny to swap in my 88 YJ. Currently I am running stock 258 I-6, TF999, NP231, 4.56 gears and 35s.
The TF999 is a three speed and I would like to have an overdrive gear. I found that the Dodge A-518 is supposed to be close to what I have now But with an overdrive. Does anyone know if this will bolt up or can anyone give me an idea on what tranny to look for? I do want to stay with an auto and do not want to get my first gear any higher than it already is.
Would like to hear comments and suggestions.
Thanks GFSmith
**DONOTDELETE** 03-25-2000 03:32 PM
Re: Tranny Swap
The only overdrive automatics that would fit your engine without adapters are the AW4 from the XJs and early '93 ZJs or the 42re/A500 from the newer ZJ 4.0s.
All Dodge transmissions have a different bolt pattern for the engine. Both Jeep overdrive automatics require computers for shifting, and are longer than the 999 you have now. Neither are readily adaptable to your Jeep unless you swapped in the wiring and EFI from a newer Jeep, which aint easy. Hope this helps, good luck!
