How much space between fan and radiator on 258?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-12-2001, 11:36 PM Thread Starter
I was curious how much space you guys have between the fan and radiator on your 258. I've had to bend the blades
back so that my radiator doesnt' get a shave. I've already had to repair the radiator due to minor extraction difficulities!
Thanks
Alec
'78 CJ7 258 T18/dana 20...dana 30/amc 20 w/ mosers & lockrights...
'glass body w/ tied in full cage...warn x8000i
http://members.aol.com/fastflyn31/page1.html
Alec78CJ is offline
post #2 of (permalink) Old 03-13-2001, 12:01 AM
Re: How much space between fan and radiator on 258??
Alec-
Most of the time the fan starts eating the radiator when either (the wrong type) a 3 core radiator is installed and/or your motor mounts are shot (too soft).
You should be able to get your thumb between the two (not while running) 1/2" +
JAF
Jaffer is offline
post #3 of (permalink) Old 03-13-2001, 12:21 AM Thread Starter
After I was hit by that drunk driver...the shop I took my Jeep to installed a 3 row modine radiator...I also have had
on going motor mount problems...I cant' seem to keep the left one together for more then a few minutes...I'll be putting on
a set of those MORE mounts soon...My fan hits the radiator when I'm 4wd and I turn the steering wheel...Replacing radiators
isn't cheap!
Thanks JAF
Alec
Alec78CJ is offline
post #4 of (permalink) Old 03-13-2001, 05:09 AM
jeepgod's Avatar
front of the fan... to the center of the grille mounting hole (the center one underneath)... 6"....
http://www.jeepgod.net
jeepgod is offline
post #5 of (permalink) Old 03-13-2001, 07:41 AM
I had the same problem after installing a three core radiator . I searched the junk yards until I found a shorter fan spacer that gave me good clearance from the radiator and my other belt pulleys . I am running the stock four blade fan . If you can not find a shorter fan spacer you could shave yours off a bit at a machine shop . Hope this helps , ken
post #6 of (permalink) Old 03-13-2001, 10:01 AM
Alec, I just went thru the exact same mod. my radiator was shot and replaced with a 3 row, well i didn't realize there was so little room for expansion in there.
the choices were search for a shorter shaft or move the radiator. i moved the radiator to the front of the grill/bracket and have plenty of room now. plus it's FREE!!
just pull off the grill and make a small bend at the bottom of the grill so you can slide the grill back on allowing for more room between the fan and the core. install the bolts from the other direction after you move the retainers to the radiator and VIOLA (sp)!!
you got it!
i hope this still works with the glass front end, let us know
by the way, this idea came from this board! thanks again guys/gals
83 CJ-7 TF-999, Original stock EVERYTHING when purchased. Now added leafs, shackles and shocks with new 33's. AND FINALLY PAINT !!!!! Now lets break something!!!
