Changed engine, now got clutch problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-11-2001, 07:19 PM
I swapped my tranny 2 mo. ago (AX15); new clutch kit and slave cylinder. Everything worked well. This week I put in a different 258 and now the clutch will not fully disengage when you push the pedal. I have bled a quart of brake fluid through the darned thing and no change.
I have to shut off the engine at stop signs to get it shifted into gear without grinding.
Could this be the clutch master cylinder?
Please help!!!
Lowrange
Email: [email protected]
87 Wrangler, 4.2L, Weber carb., HEI, AX-15, Procomp 2 1/2" lift, Procomp 3000's, Superwinch
post #2 of (permalink) Old 03-11-2001, 07:29 PM
Re: Changed engine, now got clutch problem
Did it work after changing engines?. It could be a master or a slave cylinder problem.
post #3 of (permalink) Old 03-11-2001, 07:35 PM
It worked for a short while, maybe an hour during a 100 mile drive. The slave cyl. was new 2 mo. ago. I was wondering if the master cyl. should be rebuilt or replaced. Is there a way to check it?
BTW, I checked & found no fluid leaks.
Lowrange
post #4 of (permalink) Old 03-11-2001, 07:40 PM
It's probably one or the other. Put a cap on the output side of the Master cylinder. If the clutch pedal goes down when you step on the clutch then that is where the problem may be.
post #5 of (permalink) Old 03-11-2001, 07:47 PM
The pedal feels normal and the clutch disengages, just not completely. I jacked up one rear wheel. With engine running and clutch pedal pressed, the wheel turns. If I shut it down,put it into reverse & restart it - - the wheel turns backward.
I can hold the wheel from turning with my hand while someone starts the Jeep and holds the clutch pedal in. If I let go it turns again.
Lowrange
post #6 of (permalink) Old 03-11-2001, 07:55 PM
That shows your clutch is not disengaging completely. That is why it won't shift properly.
post #7 of (permalink) Old 03-11-2001, 08:04 PM
Did you use the same flywheel? Also check that you used dot 4 fluid. Dot 3 won't work, it will boil and put air in the system.
dorfs is offline
post #8 of (permalink) Old 03-11-2001, 08:09 PM
Same flywheel, clutch, slave cyl., new engine and pilot bearing.
Lowrange
post #9 of (permalink) Old 03-11-2001, 08:19 PM
Thanks Lind & dorfs! I will check the fluid type and try rebuilding the master cyl.
Lowrange
post #10 of (permalink) Old 03-11-2001, 08:26 PM
when you bled the system, did you remove the slave cylinder from the bellhousing and push the rod in, or just bleed it hooked up? if you dont remove it to push it all the way in, you could pour a bathtub full of fluid thru it without getting all the air out. check that.. i was thinking of the standard hydraulic setup, not the concentric bearing.
paw print
yjdave is offline
