-   -   Changed engine, now got clutch problem (https://forums.off-road.com/jeep-short-wheelbase/60910-changed-engine-now-got-clutch-problem.html)
**DONOTDELETE** 03-11-2001 08:28 PM
Re: Changed engine, now got clutch problem
I would think it probably is the master cylinder. I've never had good luck rebuilding them...kind like brake master
cylinders. I still would test the master cylinder first. It could be something else. Even new parts can go bad.
**DONOTDELETE** 03-11-2001 08:37 PM
YJdave,
No, I bled the system with the slave installed in the bellhousing and the engine/tranny bolted together.
Thanks for your help.
I just realized you are in Ocala and I'm in Jax.
Lowrange
Email: [email protected]
87 Wrangler, 4.2L, Weber carb., HEI, AX-15, Procomp 2 1/2" lift, Procomp 3000's, Superwinch
**DONOTDELETE** 03-11-2001 08:41 PM
If it worked for a while after you reassembled it it should have been bled OK at that point. Something else happened.
**DONOTDELETE** 03-11-2001 09:18 PM
I just checked the brake fluid I was using - it's D.O.T. 3. Is there really that much difference? It would seem you would have to use the cluth ALOT to make it boil.
Lowrange
**DONOTDELETE** 03-11-2001 09:23 PM
If the fluid type was the problem wouldn't the clutch then be OK when you first start the vehicle before anything gets warm?
dorfs 03-12-2001 11:18 PM
Another thought would be to check the crankshaft end play on the new engine.
