oil pressure again - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-11-2001, 04:04 PM Thread Starter
oil pressure again
i did pack the oil pump with petroleum jelly i did torque the cover down i did torque the timing cover down the only thing i didnt do was replace the front main seal on the timing cover ( i know stuopid but i was in a rush to make it run had a jamboree the next day to go to) so could any one tell me if the front main seal on the timing cover could be the culprit for my no idle oil pressure or could the timing cover not be seated proprerly i know the when we were at the jamboree every time i did a mud run or a water crossing the oil pressure came back and stayed till the water was gone or the mud dried out please help
jeep the first 4 wheel drive the only 4 wheel drive
3jeepguy is offline
post #2 of (permalink) Old 03-11-2001, 04:25 PM
Re: oil pressure again
If it's a 304 I doubt if the front main seal would be a problem. The gasket under the timing cover would cause a problem if not seated or a bad gasket.
post #3 of (permalink) Old 03-11-2001, 05:10 PM
Official Historian
WILL's Avatar
The engine seals will only keep the oil from leaking out. The pressure comes from the resistance to the oil from getting out of the bearings. If the bearing clearances are too big, the oil will flow out faster with less pressure. One other thing to check is the oil bypass valve. Make sure the valve is not stuck open and that the spring is stiff enough to keep the pressure up. I stretched my spring a little at a time to get the oil pressure where it should be. Stretching the spring only affected the maximum oil pressure though, not the idle oil pressure.
79/CJ-7/AMC360/TH400/Q-TRAC/d30/d44/33's/RS9000s/Herculiner/Pro-jection 2D/MSD/4.10s/lockrights
WILL is offline
post #4 of (permalink) Old 03-11-2001, 05:47 PM
Yep, it could be cam brgs.
I'll ask again...When you went into the pump, did you check the clearance between the gears and the base of the casting ?
