NP 205 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-11-2001, 02:18 PM
NP 205
How would you rate the NP 205 vs. a D18/20/300? Where is a good place to find a NP 205, ie what vehicles came with them from the factory. Doesn't the NP 205 come in a divorced version? Again, what vehicle would I find one of those in? Thanks
Also, what sort of t cases do they put in 1 ton trucks.
"When in doubt go faster"
'64 CJ5, 351W, T-18
post #2 of (permalink) Old 03-11-2001, 02:24 PM
cj7jeep
Re: NP 205
I got mine out of a 76 Blazer. I believe most 70's part time GM's had them, not sure of the years. My 82 GMC does not. They are bullet proof, but not as low geared as the d20 and d300.
post #3 of (permalink) Old 03-11-2001, 02:24 PM
Re: NP 205
I don't know too much about this, but I'm pretty sure that all of the dodge 205's are divorced. I've got an article in 4wheel & off-road with all the info. I'll post it tomorrow when I get home from work.
--Laugh and the world laughs with you. Cry and the world laughs at you.
post #4 of (permalink) Old 03-11-2001, 03:30 PM
Re: NP 205
A copy of that article would be great. Thanks
'64 CJ5, 351W, T-18
post #5 of (permalink) Old 03-11-2001, 03:43 PM
Re: NP 205
NP205 is much stronger than any jeep t-case,but the gearing is not as good. One problem you might have with putting one in a CJ5 is that it is longer than a jeep t-case, so your rear driveshaft will be even shorter than it is now, and if your jeep is lifted a lot, you will go through U-joints fast.
78 CJ5/360
post #6 of (permalink) Old 03-11-2001, 04:18 PM
Re: NP 205
Actually I plan on putting it in a Willys wagon setting on a 1 ton under carriage.
'64 CJ5, 351W, T-18
post #7 of (permalink) Old 03-11-2001, 05:15 PM
Re: NP 205
Not sure if this is the article that "gmoody" was thinking of, but in the April 2000 issue of 4Wheel & Off-Road, there is a pretty good article pertaining to the NP 205 T-case among others. According to the article, it can be found in the following vehicles:
'69-'73 Blazers and Jimmys w/ auto trans.
'73-'74 Jimmys w/ auto trans
'70-'73 GMC pickups and Suburbans
'75-'79 GMC and Chevy pickups w/ manual trans
'78-'79 Broncos
'81-87 Chevy and GMC K3500 pickups
'69-'74 Dodge Power Wagons
'80-'84 Power Wagon W200s, W250s and W300s
'76-79 Ford F-150s & F-250s
'76 Int'l pickups (probably other years too, but this one I know first-hand) [img]/wwwthreads_images/icons/smile.gif[/img].
Additional Info:
NP-205 has a low range of 1.96:1. Can be combined with part of a NP-203 to obtain the low range ratio of 3.96:1 (probably not adviseable in a CJ-5 however). Can be converted to a twin-stick setup fairly easily if so desired.
That info should give you a start as to where to look for one of these cast-iron beasts. Hope it helped a little bit!
--Digger--
http://www.users.qwest.net/~ascanlon
post #8 of (permalink) Old 03-11-2001, 06:09 PM
Re: NP 205
yup, that sounds like the one
<font color=orange>--Laugh and the world laughs with you. Cry and the world laughs at you.
post #9 of (permalink) Old 03-11-2001, 07:19 PM
Re: NP 205
Hey-On the '76-'79 Fords there was a 'divorced' version NP205.
MARK (OIIIIO) LANGMOTORSPORTS
1977/CJ7/GLASSTUB/460CIFORD/C6AUTO/4"LIFT/33'S
post #10 of (permalink) Old 03-11-2001, 08:17 PM
I Do This For The Glory
JEEPN's Avatar
Re: NP 205
They were also found behind the heavy 3/4 ton Chevy trucks in the early 80's. My brother just picked up a 3/4 ton '83 with it behind the SM465, slip yoke of course.
JEEPN
Winter Harbor, Maine
'81 CJ-8 Scrambled!
JEEPN is offline
