Air Tank ideas - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-21-2000, 06:31 PM Thread Starter
Air Tank ideas
how are you folks handling the on board air storage problem?
iM not too keen on pressurizing the rool bar, and dont plan on tube bumpers.
who makes some small tanks and where do they fit? on a CJ5 no less!
thanks
OzarkJeep
In need of a T18 tranny!
ozarkjeep is offline
post #2 of (permalink) Old 03-21-2000, 06:41 PM
TOM85CJ7's Avatar
Re: Air Tank ideas
I have a 3 gallon tank on my CJ7. It is mounted in front of the gas tank above the rear differential. I don't know if this space exists on a CJ5. My tank is from one of those hot dog style contractor compressors. I bought the whole compressor with a burned up motor for $35 from a loacl compressor repair shop. I used the tank, gauges, switch, and everything else but the electric motor. It was well worth the $35.
Tom
<font color=green>85 CJ7-4.2L,T-176,D300,2.5"lift,32"BFG MT,Durabak,York-Air,HEI</font color=green>
TOM85CJ7 is offline
post #3 of (permalink) Old 03-21-2000, 06:46 PM Thread Starter
Re: Air Tank ideas
thats another question i had, do the 120 volt switches work with the 12 volt compressor clutch? I guess they do since your using htem, cool that answeres that
OzarkJeep
post #4 of (permalink) Old 03-21-2000, 08:32 PM
z50k2's Avatar
Re: Air Tank ideas
I am planning for my air tank to go beside the transmission in the skid plate (driver's side). There seems to be plenty of room. BTW I have fenderwell headers and side pipes. I just got my compressor mounted and am drawing a new diagram that I got ideas from the compressor sites. Any input or help is appreciated..Thanks...
Ricky...seeya...
1979 CJ-7 401 T18
z50k2 is offline
post #5 of (permalink) Old 03-21-2000, 08:51 PM
Re: Air Tank ideas
I know you said you weren't planning on tube bumpers for air tanks, but I just wanted to put this in. Remember how everyone was bashing using a typical tube-bumper for an air-tank because the welds weren't right for it? Well, you could just have the correct ends put on and welded the right way, along with the rest of the fittings, and it would work quite nicely. I've heard of some people putting air-tanks under the hood, and while it could be made to fit with an inline 4 or 6 I think it would be too hot in there and be constantly blowing the burst disc. How about on top of the rear fenderwells, between the sections of roll-bar? You could even strap it vertically to the roll-bar itself and not have to bolt it through the sheet-metal.
Sycho15 is offline
post #6 of (permalink) Old 03-21-2000, 09:13 PM
Bryan's Avatar
Re: Air Tank ideas
I got my tank from rubicon express, $70. It has all the NPT holes you need. 6"x24" tube. 2.5 gallon, I think. I mounted it on the rear fender well of my YJ. Fits perfectly, stays clean, and it draws strange looks from rear seat passengers.
Bryan is offline
post #7 of (permalink) Old 03-21-2000, 09:20 PM
jeepgod's Avatar
Re: Air Tank ideas
yes i am planning on putting mine next to the tranny.. above the skid plate.. since i too will be running the fenderwell headers.. i know wally mart sells i 2.5 or 3 gallon tank, with fittings, hose and everything you need for like 70-80 bucks.. you could also put it behind the back seat on the cj7's.. sorry i know that doesnt help you 5 guys out at all... you could just get a 7 and be donw with it.. hehehe..
survival is instinct, but living takes guts
jeepgod is offline
post #8 of (permalink) Old 03-21-2000, 11:25 PM
Re: Air Tank ideas
I solved the problem by getting a CO2 tank from a Pepsi guy and putting a regulator on it. $12. to fill the 20lb tank, it works like a charm,is portable, and it will fill many,many tires very fast. Just strap it in your jeep and go.
post #9 of (permalink) Old 03-22-2000, 12:34 AM
Re: Air Tank ideas
I went to a truck (semi) sakvage yard and picked through their pile. Found a 3 gallon tank with a 125 psi pop off, dump valve and all of the fittings. $40.00
Most of my buddies have had similar luck at truck salvage yards all over So. Cal.
Axlesupagain
post #10 of (permalink) Old 03-22-2000, 06:55 AM
Re: Air Tank ideas
I got an old, but in good shape, fire extinguisher bottle, painted it and installed it in the engine compartment on the driver side fender in place of the jack. I threw the jack in the back with my tools.
Yes the 120 V switch will work. All it does is close a circuit and let the current go through. It doesn't matter if that current's voltage is much less than it supposed to handle.
Hope this helps.
A.B.
