94 JGC. got spark, won't start. help please - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-09-2001, 08:34 AM Thread Starter
94 JGC. got spark, won\'t start. help please
here is the situation: 1994 jgc 4.0L. tuesday night, my neighbor (his truck) started it and moved it around in the drive. wed morning, went to start and it would turn over, but not fire. wed night i pulled a spark plug and there is spark, and the plugs are wet. when i push the little valve in the tes-fitting in the fuel rail, it barely shoots out, maybe 3in. or so. i think i can hear the fuel pump run. my neighbor has been renting it to his brother for the last 4 months and his brother ran it out of gas twice. i am going to put new plugs in it tonigh (it needs them!)and try to do some other diagnostic work. anything i should look for? tried checking the codes and all i get is a 55. is the fuel pressure supposed to be 37-41 psi on these 4.0L also? thanks for any info! matt
jeepnmatt is offline
post #2 of (permalink) Old 03-09-2001, 08:35 AM Thread Starter
Re: 94 JGC. got spark, won\'t start. help please
NEW DEVELOPMENTS! this morning, just for fun, i thought i'd try and start it. it cranked over, idled kinda rough, then smoothed out. i let it run for 2-3 minutes to help charge up the battery and turned it off. immediately tried to restart it and it sputtered once or twice and then would only turn over, not fire. any possiblilty this could be the Crank Position Sensor? or do you still think its the fuel pump? i am going to work on it tonight. thanks for any info! matt
post #3 of (permalink) Old 03-09-2001, 08:39 AM
Here's my idea.. and I'm shootin' in the wind on this one... The SMPI guys will know more than I do on this one...
Check the CPS senser. You may be getting spark, but:
1. Is it at the right time?
2. A fuel injector should pulse at, or around the same time.
3. Do you hear the an injector fire?
If no injectors are firing, you've got to find out why...
LEVE
