Pitman arms - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-08-2001, 08:40 PM Thread Starter
Pitman arms
Hey, does anyone know of a shorter pitman arm for a saginaw setup that I might find in a salvage yard? I have setup wagoneer D44 axles and the tie rod does not clear the springs at all, so I am going with a spring over steering setup, but now I have found that the steering box is not far forward enough to work with the current pitman arm. I could move the steering box forward, but that would be a major PITA in my opinion, I would much rather just find a shorter pitman arm so the drag link does not interfere with the tie rod. I realize I would lose some steering radius, but I don't think that will be an issue, because I cannot get full steering lock anyway on the box without the tires rubbing the springs. Thanks.
John
70 Jeepster with "Hurc package"
225 V-6/TH400/D18, D44's locked 4.88, 8" SOA 36's
48 flattie 225 V-6 HEI/T14/D20, D30/D44 31's.
98 Tacoma EC V6, 2" lift, 33's, and NO swaybar [img]/wwwthreads_images/icons/smile.gif[/img]
Hurcules is offline
post #2 of (permalink) Old 03-08-2001, 08:54 PM
Re: Pitman arms
call Tri-County Gear in the back of any jeep mag. They Might have one Matt
post #3 of (permalink) Old 03-09-2001, 12:44 AM Thread Starter
Re: Pitman arms
Thanks, I think I have decided to move my box forward all the way it can go and just run with a waggie steering shaft, then move the front axle up a bit to get the wheelbase up to 104" or so. I figure this is my time to make a really beefy steering box mount, so I might as well just move the box.
John
Hurcules is offline
post #4 of (permalink) Old 03-09-2001, 01:02 AM
Re: Pitman arms
Have you tried a Skyjacker droped pitman for a J series pickup. The bend just might clear it for you. Take a look and talk to them about it. Then you won't loose your turning radius. Other wise a YJ arm is shorter, and should fit if it is all stock waggie parts.
Jason
<font color=green>----------------</font color=green>
<font color=green>[]llll[] '90 YJ</font color=green>
<font color=green>"There are no shortcuts to any place worth going."-Anon.</font color=green>
post #5 of (permalink) Old 03-09-2001, 03:18 AM Thread Starter
Re: Pitman arms
A dropped pitman arm would not work with spring over steering, but the wrangler one is a thought, i will drop by the Jeeep dealer tomarrow and see what I find. The shorter the better, by moving my box up it is more in harms way. I am using stock waggie linkage and a box out of a 73 mando that should take a wrangler pitman arm.
John
225 V-6/SM420/D18, D44's locked 4.88, 8" SOA 36's
Hurcules is offline
post #6 of (permalink) Old 03-09-2001, 07:36 AM
Re: Pitman arms
I think the Wagoneer used a bigger tierod end than the YJ. Might have to have the hole in the YJ arm machined out to fit the Waggie tierod ends.
My Jeeps Play Cowboys and Indians!
'93 Cherokee 5" higher on BFG MTs, SYE,...
'95 Wrangler 4" up on 33 AT's, Custom bumpers,...
post #7 of (permalink) Old 03-09-2001, 09:29 AM
Re: Pitman arms
Good man, moving the box is not all that bad, and much better than the short arm.
