Re: Side Exhaust
When I bought my Scrambler it had headers that exited the fenderwell, went straight into a cherry bomb, glass pack, whatever they are called now.... and then a small 90 degree that turned it out right before the wheel. There was no room in there for a muffler and a cat as I can remember. I still have the complete set up sitting at the house, I'll take a look at it when I get home and compare it to the size of my cat and my muffler to see if it there would be enough room to mount all that stuff before going out the side, but I would have to agree with Jeepgod that you should take it out the rear of the Jeep, you'll be much happier. If you can't afford to go to a muffler shop, Take some wire or something and use it to make a template of what you need to go over the axle and then go to your local auto parts store to look at the pieces they have in the back (they always have over the axle pieces pre-made for different brands of vehicles, I used to work in auto parts years ago) and see if you can find something that will fit your needs.
82 Scrambler, 360, T5, D300, 4" SUA, AMC20 w/rear discs and Somers Bros 1 piece axle shafts, D30, 3:73's, and lockers.
Smithville, Texas
Member TX4X4 Cyber Club
