Gasket between T-5 and Dana 300 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-07-2001, 11:38 PM Thread Starter
Is there supposed to be a gasket between a T-5 and Dana 300 transfer case? Exactly where do put the sealant? What kind of sealant to use?
Thanks.
zimm is offline
post #2 of (permalink) Old 03-07-2001, 11:46 PM
Re: Gasket between T-5 and Dana 300
NO gasket. A little silicon seal is a good idea. BUT, make sure you replace the oil seal that is in the back of the T5 that seals the 300 input shaft. If you don't I GUARANTEE a leak!
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
post #3 of (permalink) Old 03-07-2001, 11:47 PM
chasejeep7
I just used your standard liquid gasket seal. I think it was the blue gasket stuff. Anything should do as long as it holds up to gear oil. Just apply it to the outter rim where the bolt holes are and compress them together.
Good luck.
chase
<font color=blue>C</font color=blue><font color=red>hase</font color=red><font color=blue>J</font color=blue><font color=red>eep</font color=red><font color=green>7</font color=green>
post #4 of (permalink) Old 03-08-2001, 12:09 AM
You can get a gasket, but a little silicone works just as well in this application.
Ray
post #5 of (permalink) Old 03-08-2001, 09:53 AM
I've never seen a gasket for that application. Mine came from the factory without one.
Brad
post #6 of (permalink) Old 03-08-2001, 12:03 PM
No, ther is no gasket is is not supposed to have one. If you notice on the T-5 there is a notch at about 7 o'clock and that is to let any fluid that is leaking from your T-5 or D300 out. I would not recomend using silicone or anything, if you do and you spring a leak where is the fluid going to go?
Michigan Jeepin Madness
shawnscj is offline
post #7 of (permalink) Old 03-08-2001, 12:08 PM
The 2 cases don't match all the way around. I would put silicon on the mating surfaces. There is an area near the bottom where they don't mate. MIne came from the factory with black silicon on the mating surfaces.
Brad
