Scout or Waggie 44s? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-06-2001, 11:41 PM
What is total width of scout 44s and waggie 44s, i am not going to shorten them, so which would be the closest to my current axle width?
85 scrambler
'85 Scrambler
Shell Valley Fiberglass tub
4" Superlift, 2 inch homemade body
33 x 12.5
stock 258
post #2 of (permalink) Old 03-06-2001, 11:51 PM
Re: Scout or Waggie 44s?
not sure about the scout but the waggie is only 4 inches wider so that would be 2 inches on each side
jeep the first 4 wheel drive the only 4 wheel drive
3jeepguy is offline
post #3 of (permalink) Old 03-06-2001, 11:54 PM
If you're looking to run them full width...the scout axle would be a better choice. They have a 5 on 5 a half lug pattern that
you'll need. The waggie axles are a bit wider but carry a 6 lug pattern. Both 44's (unless you have an 80's amc/jeep waggie).
The scout front d44 doesn't have the caster that you need with a CJ. Or you could mix and match. Change the 6 lug to 5
lug...the options are endless. Search this topic.
Alec
'78 CJ7 258 T18/dana 20...dana 30/amc 20 w/ mosers & lockrights...
'glass body w/ tied in full cage...warn x8000i
http://members.aol.com/fastflyn31/page1.html
Alec78CJ is offline
post #4 of (permalink) Old 03-07-2001, 12:13 AM
okay thanks
'85 Scrambler
33 x 12.5
stock 258
post #5 of (permalink) Old 03-07-2001, 01:11 AM
I Do This For The Glory
JEEPN's Avatar
The Scout axles are 2" wider per side (4" overall) than the wide track axles. I'm running them, as are a few others on this board. Easy swap also, but no caster = sucky steering.
JEEPN
Winter Harbor, Maine
'81 CJ-8 Scrambled!
JEEPN is offline
post #6 of (permalink) Old 03-07-2001, 05:53 AM
jeepgod's Avatar
wagoneer front d44 have larger shafts.. than the scouts.. and the parts are cheaper.. even when you use cj parts instead of scout...
http://www.jeepgod.net
jeepgod is offline
post #7 of (permalink) Old 03-07-2001, 08:42 AM
JEEPN's Avatar
What size are the Waggie shafts?
JEEPN
'81 CJ-8 Scrambled!
JEEPN is offline
post #8 of (permalink) Old 03-07-2001, 10:08 AM
Round here, a 44 is a 44 and there isnt a difference other than length...I've got a stack of chevy's/scout/waggy axle shafts , and other than lenght they are the same dia...
post #9 of (permalink) Old 03-07-2001, 11:39 AM
jeepgod's Avatar
well.. i dont know the exact diameter.. but.. ive got a d44 closed knuckle in the back yard.. and the shafts are in the shed.. they are d30 size.. SUX!
and the scouts are the same.. for me to convert that closed knuckle to disk.. i could use the d30 outers.. but i needed a scout outer shaft due to having the larger u-joint.. unlike the d30.. but.. cant use that d30 stuff with my waggy d44..
jeepgod is offline
post #10 of (permalink) Old 03-07-2001, 12:20 PM
OK!! You got me there, I havent messed with the closed knuckle stuff...The ones I have seen are a little smaller in diameter, but the have also had a smaller spline count too!!
