MPI problems again??? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-06-2001, 01:39 PM
Robert87yj
Having problems/doubts with my MPI. Wrote an email to Hesco. Please tell me what you guys think. Am I off base here or do I actually have a problem?
I just put on a new fuel pump and hesco 4.0 head on my 4.2 block on my 87 wrangler. I have run the MPI system for about a year with a different 4.0 head that I just couldn't get to stop leaking antifreeze. I started it up last night after about one and a half weeks with the battery disconnected and it had normal rmps, about 650-700 or so, like it did before I disconnected the battery. Is the computer supposto reset its self if the battery wire is disconnected? I remember reading somewhere that if the computer needed to re-learn the rmps would be high until I put a few miles on the engine like it did when I first put the MPI system on.
Is there something wrong with the computer if the rmps won't increase if the battery is disconnected for an extended period of time?
Thanks,
Robert Smith
Thanks in advance...I'm getting frustrated with this MPI system. It runs great, but the computer is the second one I've had on there. The first one was defective, hesco sent a new one, now I'm wondering if this one is defective also because it won't reset.
Robert87yj[img]/wwwthreads_images/icons/tongue.gif[/img]
4.2 w/<font color=blue>(4.0 head & MPI)</font color=blue> (jeep is down need a new head)
Process of a moonguy after beer
[img]/wwwthreads_images/icons/mad.gif[/img] [img]/wwwthreads_images/icons/frown.gif[/img] [img]/wwwthreads_images/icons/crazy.gif[/img] [img]/wwwthreads_images/icons/wink.gif[/img] [img]/wwwthreads_images/icons/smile.gif[/img] [img]/wwwthreads_images/icons/blush.gif[/img]
post #2 of (permalink) Old 03-06-2001, 02:15 PM
Re: MPI problems again???
Robert,
Here are a couple of things to think about:
* There are two power wires. One is switched and the other constant. Are you sure you disconnected the constant power?
* If the constant wire has been interuppted for more than a few minutes, the computer will lose the memory of what it learned while running. It should start over like it did the first time you started it. Even when I have disconnected the power (both wires) mine seems to run better than it did the first time it started up.
* The high RPMs are definitely programmed for the first minute or so, but I don't remember mine having higher rpms during the computer's 'learning period'.
* How does it run? Is it missing at any RPMs, or is it smooth and strong through the whole power band?
* If you are experiencing any performance loss at higher or lower RPMs it could be the gap on the crank sensor. The first one I got didn't have the paper button. I set it at the recommended gap and it wouldn't start. Hesco recommended increasing the gap to something like .070". It started, but missed at higher RPMs. I decreased the gap to around .050" and it is perfect. The crank sensor is extremely sensitive. You may play around with that to see if it is the problem.
-raymo
Scrambler
258 4.0 Head/MPI,NV4500,D300,4.10's,HS9500
raymo is offline
post #3 of (permalink) Old 03-06-2001, 02:59 PM
Robert87yj
I removed the battery complety. So there is no way it still had a power wire connected.
All cylinders were runing rich before so I wanted the computer to reset, it should have if I disconnected the battery right?
post #4 of (permalink) Old 03-06-2001, 03:30 PM
Have you run the error codes by hooking up a check engine light? That would be the first thing I would try. It sounds like it could be something like an oxygen sensor. I don't know what other things might be affecting it, but I doubt it is the computer.
As far as taking the battery out, that would definitely reset it.
-raymo
Scrambler
raymo is offline
post #5 of (permalink) Old 03-06-2001, 03:41 PM
I'm going to butt in where I know nothing and make a remark so take what I say with a grain of salt... the size of a water softener pellet....
1. If the battery was disconnected, the ECM should show that disconnect within the last 50 on/off cycles. That's a consistant code for Chrysler products.
If it's not showing the disconnect... that alone would raise red flag. The process of the re-learning... Yep, that's the second red flag raised. I vote for a bad ECM unit.
As a double check, force an error, such as uncoupling a sensor and see what the computer will and what it will not pickup.
2. If the engine was running rich after the new fuel pump, it may be delivering more fuel than the regulator can handle. Check the input pressure and the return line pressure.
3. Or... the return line from the regulator may be too small. If you've used an OEM dia. vapor return line as a fuel return line, this could be the problem.
On my Howell TBI I had replaced the return line with a 3/8" line to move the fuel back to the tank fast enough not to raise the pressure at the regulator. This prevented clouds of black smoke from following me. That OEM line enriched the fuel mix because the regulator could not handle the pressure given the smaller OEM return line diameter.
LEVE
