12 degree shim after lift! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-06-2001, 06:56 AM
sas87yj
after talking with tom wood last night, he came up with me needing a 12 degree shim to fix rear shaft angle after 4.5" RE lift. i couldn't install lift without dropping shaft and the shaft will not go on now due to the extreme angle. granted i DID NOT lower the transcase with the 1" pucks but DID install the 2.5 degree shims. laid the shaft in there best i could with yoke almost fully extended and u-joint barely on diff yoke to measure the shaft angle with a protractor on bottom of shaft. measured 40 degrees from the verticle. diff measured 8 degrees from the verticle. tom couldn't believe the 40 degree, not with only a 4.5" lift. to get a better measurement i measured from the ground up to center of tail shaft and from ground to center of diff yoke. 23" and 13" respectively. slope distance from rear seal of transcase to center diff yoke = 18.5". this equates to 32 degrees (opposite/hypotenuse = sin). tom liking that measurement better did a calc of his own and figures a 12 degree shim along with the SYE and CV shaft should work. any opinions from you driveline experts out there? what about the diff being shimed that much-will it lube itself correctly?
thanks,steve
post #2 of (permalink) Old 03-06-2001, 07:59 AM
RickB's Avatar
Re: 12 degree shim after lift!
I'm not a expert by any means, but I've never heard of anyone using that much of a shim. I'm thinking that relocating the spring pads would be better.
RickB is offline
post #3 of (permalink) Old 03-06-2001, 08:18 AM
as far a lubrication goes, i would recommend a product called "Lucas Oil Stabilizer". the display at the autoparts stores shows two different sets of five plastic gears that are stacked vertically. one set has only motor oil in it and the other has 20% Lucas and 80% motor oil (manufacturer recommended percentages). top gear runs dry in the set with oil only. the Lucas makes the oil "sticky" and lubricates the top gear. it is also good for your seals. i have had very good success using it in manual transmissions that were noisy or hard to shift and noisy transfer cases. i also run it in my differentials at the recommended 20% Lucas to 80% gear lube. it is usually $8 a quart from NAPA, CarQuest, and some truck stops carry it. hope this helps! may want to do an internet search for more info. matt
jeepnmatt is offline
post #4 of (permalink) Old 03-06-2001, 11:26 AM
dennisuello's Avatar
my RE 4.5 should be here pretty soon, so I'm getting ready to install it, however I can't get sye right away. is it at all drivable without sye, or i need to get it before i put the lift on?
Denis <><
'92 YJ i6, 32x11.5x15 bfg ATs, 4.5 RE lift is coming soon
http://dennisuello.tripod.com/
http://albums.photopoint.com/j/AlbumList?u=1570804&f=0
dennisuello is offline
post #5 of (permalink) Old 03-06-2001, 06:03 PM
sas87yj
dennis-
i would be a good guinea pig for your future project! fire away any questions and i will tell you some things up front![img]/wwwthreads_images/icons/smile.gif[/img]
1)spray -wd40 or equal all shackle and u-bolts ahead of time and you can even try to break loose all if time permits.
2) i believe you will notice that the top 2 shackle bolts at rear will not be able to pull out because gas tank is in way. these will have to be cut off.
3) watch out for the vacuum lines to the 4wd unit on front axle when installing front springs. they will need some slack.
4) also same with the emergency cables, especially pass. side when doing rear springs.
5) good luck removing pitman arm! get a good quality USA puller.6) will need a pickle fork for taking pitman arm off tie rod.
7) need 4 jack stands, couple bottle jacks, floor jack and timber.
i did not drop transcase the 1" as kit comes with. i did install the little 2.5 degree shims on rear. i had to drop rear shaft to install springs-was binding. with lift complete, rear shaft will not connect to yoke at diff. angle too extreme and even if it did go together the yoke is almost out of transcase. i can't believe even if i lowered the transcase it would be any better-well a little but i don't see how it would be wise to drive. i am curious how your lift goes! i forgot to pre-measure height of frame before so i could see if 4.5" was close. see if you can remember![img]/wwwthreads_images/icons/smile.gif[/img] good luck! steve
