Re: transfer case lowering
A 2.5" lift should not require a transfer case drop and shouldn't adversely affect your angles enough to worry about. Plus if you lower your TC you are kinda defeating the purpose of the lift to begin with which was to gain more ground clearance. I would recommend doing the lift first and seeing if you need to do anything else, I think you will find that its not necessary,
82 Scrambler, 360, T5, D300, 4" SUA, AMC20 w/rear discs and Somers Bros 1 piece axle shafts, D30, 3:73's, and lockers.
Smithville, Texas
Member TX4X4 Cyber Club
