Need some help - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-05-2001, 04:55 PM
Need some help
I just got done with my rebuild a few days ago on my 304. I pulled it out of the garage and let it idle for a while then i put a few light miles on it. It ran fine all last night but this morning when i took off in it, it would constantly sputter and stall, it only happens when it is moving. Im open for any help any of you have to offer thanks.
post #2 of (permalink) Old 03-05-2001, 04:57 PM
Re: Need some help
Sounds like a clogged fuel filter - check it out. Good Luck - Chuck.
Chuck Hadley
post #3 of (permalink) Old 03-05-2001, 05:00 PM
Re: Need some help
Was it cold? Also the carb has it been adjusted with the rebuild? Check Timing... do alittle look over and see what happens..
post #4 of (permalink) Old 03-05-2001, 05:20 PM
Re: Need some help
Timing is set, carb is set. All of that is done.
Clogged fuel filter could be the problem, what about the fuel pump?
post #5 of (permalink) Old 03-05-2001, 05:30 PM
Re: Need some help
Is the fuel filter properly installed? It should one with a dual outlet. The outlet closest to the side of the filter is for the return line and needs to be installed so that the return line outlet is on top of main outlet (not lower than than the main outlet) or it can make your motor do what you describe. If you do not have a return fuel line, you have found at least one of your problems.
Good Luck!
Kriss
post #6 of (permalink) Old 03-05-2001, 08:37 PM
Re: Need some help
Just a side note. You really should not let a fresh engine idle, turn the idle speed up to 1200 or so for the first few hours. I don't let mine get below 2000rpm when first starting, and for a few hours, Then I will drop it down to 1200 or so for driving.
If it comes with instructions, then it's not what the pros use.
