Broken Hub Question/D44 Backing plate question` - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-05-2001, 07:10 AM
Hey All,
We had a club trip yesterday and I have some problems. My front rear has been getting worse and worse and I was planning on rebuilding front and back rears when it goes...
The front drive shaft is spinning but the tires arent. How can I figure out if a hub is broken? Do I have to pull them off and look? Or is there an easier way?
Next, I lost my tire on the way out of the trail. Its a D44 from a Scout. It looks like the bearing went and the axle seperated from the backing plate. The backing plate is now destroyed. Where can I Buy a backing plate?
Thanks.
84CJ7 SOA,35's,OnboardAir,Dual winches,Full Cage,Snorkels, and more
OverMost 4WD Club
JerseyWheelers Club
post #2 of (permalink) Old 03-05-2001, 01:39 PM
Re: Broken Hub Question/D44 Backing plate question`
taking it to the top again. Can anyone help out?
OverMost 4WD Club
JerseyWheelers Club
post #3 of (permalink) Old 03-05-2001, 02:57 PM
To see if the front problem is the hub lock them in and jack the front end off the ground. Put the transfer case in 2wd and turn the front driveshaft by hand. While turning watch the front axle u-joints. If they are turning and the tires aren't you have a hub problem.
'75 CJ5,258 w/Howell EFI,T18a,4.27's,33's,On-board air,Warn 8274
post #4 of (permalink) Old 03-05-2001, 02:59 PM
Thanks. I will try that.
OverMost 4WD Club
JerseyWheelers Club
post #5 of (permalink) Old 03-06-2001, 09:56 AM
Can anyone give me some info on the rear axle question? I dont know where I can buy a backing plate for the D44 that I have out of a scout. Thanks.
OverMost 4WD Club
JerseyWheelers Club
post #6 of (permalink) Old 03-06-2001, 09:15 PM
Try Light Line of Louisiana.
http://www.lightlineofla.com/index2.htm
Their online parts catalog shows backing plates for $20.
I'll bet that they are "Used" parts though.
You should check that the axle bore has not been ruined.
If the bearing spun, it might have distroyed the bore as well.
post #7 of (permalink) Old 03-07-2001, 07:12 AM
Can you explain what the axle bore is and what I should look for. I do appreciate the help. This is still new to me. Thanks so so much.
OverMost 4WD Club
JerseyWheelers Club
post #8 of (permalink) Old 03-07-2001, 08:16 AM
Brian-
The 'bore' is the seat for the bearing that is machined into the ends of the rear axel. If the bearing has seized, the axel shaft starts turning the whole bearing and this can and will destroy the seat by wearing it to a larger diameter and pretty much tearing it up.
By then, it's new axel housing time ...
JAF
Jaffer is offline
