Narrowing D-60s (specifically the rear axle) - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-05-2001, 12:39 AM Thread Starter
I've read tons of posts on narrowing front axles, and one post (by Jeepgod I think) on narrowing rear axles. I think I understand the front well enough, but could someone explain to me the method of narrowing a rear axle (specifically a FF D-60)?
'Gator Chaser
Sycho15 is offline
post #2 of (permalink) Old 03-05-2001, 08:28 AM
Re: Narrowing D-60s (specifically the rear axle)
This isn't a FF, but it may apply.
http://www.bc4x4.com/tech/2000/highp...iond60rear.asp
dorfs is offline
post #3 of (permalink) Old 03-05-2001, 08:43 AM
To just shorten the tubes the rossetts?(holes on the pumpkin that are filled with weld to hold the tube in) are burned out and the weld around the tube is ground off. The tube in then pulled out, cut to length, reinstalled, a jig like the one in the high pinion page is used to ensure straightness and then rewelded. As for the shaft, custom shafts can be made or the shaft can be cut down and resplined.
Good Luck
Pigpen
76 CJ5 360/T18A/Bronco gear D20/D30 big brake disc, locker/D44 big drum working on disc/ factory slip/4inch lift/33's/6000lb winch/All Fiberglass/electric fan/full cage/ appetite for MUD
Pigpen is offline
post #4 of (permalink) Old 03-05-2001, 10:04 AM
utahjeepr
My D60 FF is just about ready to stuff the tubes back in. If I had it all to do over again, I'd use a semifloater out of and E-350 Ford van. Pgpen has pretty well described the process. If you don't have a FF D60 with 1.500 axles already in it, you have to have the spindles bored out to accomodate them. Not much reason for all this work if you ain't gonna stuff 1.500 35 spline alloy shafts in it.
I am a "Sheetmetal Darwinist"
