I Do This For The Glory
Re: Problem Installing OEM Fog Lights
We did the same when I installed the lights on our '97 TJ. The switch wire was all set, so I plugged it in, but still had to power the switch (the switch is lighted, but it has no main power), which meant tapping into the orange/white wire in the gray wire block behind the dash on the driver's side. This is all from memory, and it was 4 years ago I installed them, so they may be different now. I do remember the wiring instructions that came with the "kit" were awesome. I left out the jumper to the low beam lights, so I can run them independent of the headlights, but with the running lights so they'll go off and can't accidentally be left on. I also never got the "OEM" fog lights, I used my own, which were a better quality and MUCH cheaper. It you need further help, let me know.
JEEPN
Winter Harbor, Maine
'81 CJ-8 Scrambled!
