How to tighten bench grinder wheel (don't laugh!) - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-04-2001, 07:56 PM Thread Starter
kutyafal's Avatar
How to tighten bench grinder wheel (don\'t laugh!)
Ok, so I'm not a pro. I got a 6" bench grinder and the wheels are really out of balance. It wibrates like hell. So I tried to rotate them to see if that helps and now I can't tighten the nuts enough. There's no way to lock the shaft so it won't turn and if I hold one wheel the other comes loose. I don't have an impact gun. Any trick to this?
'91 YJ,I-6,2.5" lift,Boomerangs,33s,D30,D35c,Lock-Right F&R and a light foot
kutyafal is offline
post #2 of (permalink) Old 03-04-2001, 08:12 PM
Re: How to tighten bench grinder wheel (don\'t laugh!)
All I've ever done is hold one and tighten the other. There's no other magic, at least none that I know.
Ken
greencj7 is offline
post #3 of (permalink) Old 03-04-2001, 08:17 PM Thread Starter
kutyafal's Avatar
I've tried holding the opposite wheel but then the shaft in that wheel turns. If I hold the wheel that I want to tighten then the shaft in that wheel turns! [img]/wwwthreads_images/icons/crazy.gif[/img] Nuts!
kutyafal is offline
post #4 of (permalink) Old 03-04-2001, 09:17 PM
I Do This For The Glory
JEEPN's Avatar
Take one wheel off, and hold the shaft. Then tighten the wheel. Then put the other on and tighten it using the first wheel as a break. I've never had a problem, maybe something is messed up in there and you need new wheels.
JEEPN
Winter Harbor, Maine
'81 CJ-8 Scrambled!
JEEPN is offline
post #5 of (permalink) Old 03-04-2001, 10:01 PM
Use a vise grip on the shafts ...
JAF
Jaffer is offline
post #6 of (permalink) Old 03-05-2001, 12:02 PM
69CJ5
Left-hand thread??
post #7 of (permalink) Old 03-05-2001, 12:20 PM Thread Starter
kutyafal's Avatar
Yes, the left shaft is left hand thread. That's why they alternately keep coming loose when I try to hold one wheel. I'll try to hold the shaft with a wise-grip but there is pretty slick. We'll see tonight. Also, is there a way to balance a wheel if it hits? Dressing stone maybe?
kutyafal is offline
post #8 of (permalink) Old 03-05-2001, 12:25 PM
If the wheel is off centered, try rotating the stone wheel (on the shaft) 1/4 turn at a time, tighten it down (using the vise grip) to see if you can get it more centered. Then use the dressing stone ...
JAF
Jaffer is offline
post #9 of (permalink) Old 03-05-2001, 12:26 PM
joeybcdt
Forget about swapping wheels. Pick up a trueing stone. If your wheels are hard, you'll need a soft one. If they are soft, you'll need a hard one. Sometimes, a file, or a brick, can be used to true them.
Also, test the shafts to make sure they're running true. Remove the wheels. Turn on motor. Lay a flat tool on the spinning shaft. If it lays well, the shaft is true.
Joey
