I hung the motor mount assemblies on the motor while it was on the motor stand and measured across from one side to the other. It measured 28-1/4 inches, I measured from inside of frame to inside of frame on the cjh and have 25-3/4 inches. When I got the frame mounts from the boneyard, the guy said that all engine pieces are the same for all amc v8, can I assume he is wrong? I know I have the correct frame mounts and motor mounts, it's got to be the engine brackets right. The engine pieces came with the motor out of a waggie. Anyone have the correct pieces?
Thanks again
'83 cj7
BDS 2-1/2 lift
solid rear axles
HEI, Weber (soon to be 360!!!)
ragtop
Thanks again
'83 cj7
BDS 2-1/2 lift
solid rear axles
ragtop
