-   -   Pros/Cons of Springover lift and welded front diff (https://forums.off-road.com/jeep-short-wheelbase/57507-pros-cons-springover-lift-welded-front-diff.html)
**DONOTDELETE** 02-16-2001 03:44 PM
Just wanted to get some opinions on spring over lifts and welded diffs? Specifically I am going to look at a 92 YJ with both (lift and welded diff) and wonder if its worth my time. The rear diff has a lock rite locker but the front is welded. Is this going to cause major problems?
What are the pros/cons of spring over lifts? This won't be a daily driver but I would like some reliability/drivability. Any input is appreciated. Thanks!
**DONOTDELETE** 02-16-2001 04:33 PM
Re: Pros/Cons of Springover lift and welded front diff
In the SW (I noticed you live in AZ) you are going to HATE a welded diff in front. Trying to turn on rock is bad enough with a locker, I would predict blown axle u-joints on rock with a welded diff. And if its a YJ it probably does't have locking hubs of a twin stick, so you can't even free the front end up momentarily and still retain low range.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
**DONOTDELETE** 02-16-2001 04:47 PM
One more vote against the welded front diff. I welded mine for lack of cash, and it SUCKS.
**DONOTDELETE** 02-16-2001 05:05 PM
Front welded diff a pain: Maybe--Unless you can put a rock lock on the D30 front axle. Then you can disengage the passenger side front tire even in 4wd with a welded diff. Plus you'll get rid of that nagging vacuum disconnect. It is a YJ right? I have the rocklock and it works great.
The rock lock is around $190. The spring over is what most serious off roaders eventually go to. :D How much are they asking for the jeep?
FOR SALE:D35,4.11,posi.FOR TRADE: 35x12.50 SSR wanted 35x14boggers.John-89YJ-350V8,35" SSR's, EFI,revolvers,shackle reversal,SYE,cv shaft, 4.11,locked front D30, rocklock,8.8,2"body, TJ flares.
JEEPN 02-16-2001 08:12 PM
One of two things will happen with a welded front diff in a '92:
1) You'll snap the 260X u-joints, which weak to being with.
2) You'll snap the axle disconnect system with it activated.
I won't even run it in the D44 front under the Scrambler, I shelled out the $240 for the Lockright.
JEEPN
Winter Harbor, Maine
'81 CJ-8 Scrambled!
**DONOTDELETE** 02-16-2001 08:32 PM
spring over good if done right.
welded front diff bad.
a rear that has been welded correctly is good but a welded front won't allow you to fully steer. a buddy tried it with his dana44 front and it actually caused him to flip in one spot because he couldn't turn far enough.
brian wilson
80 cj5 "high 5"
stretched to 100" wb
efi351w/np435/d300/d60fr/14br/detroits/4.56/38's
