How do I start my engine out of the vehicle???? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-16-2001, 12:09 PM Thread Starter
TOM85CJ7's Avatar
What needs to be connected for me to be able to start my engine????
The engine is still on the frame but the harness is completely gone. The solenoid is there and the starter and everything else, just don't have any wires running to distributor(plug wires are there), no computer. This is a '82 factory 258 with no modifications. All I want to do is get it running to check my head gasket for leaks.
Thanks,
Tom
http://home.off-road.com/~tom85cj7/home.htm
TOM85CJ7 is offline
post #2 of (permalink) Old 02-16-2001, 12:37 PM
Re: How do I start my engine out of the vehicle????
Well... I could tell you how to hot wire it from under the hood... Take a positive lead FROM BATTERY to the red wire on the Coil- this will give the firing system power all you need to do it turn it over now. You have to have the Ignition Module Hookedup. Take a screw driver with a insulated handle and cross the two posts on the top of the solenoid this will start the engine and let it run... Hope that helps... You could wire up a switch to the solenoid sort of like a ignition switch.. anymore questions?
post #3 of (permalink) Old 02-16-2001, 01:00 PM Thread Starter
TOM85CJ7's Avatar
I was wondering if it would work without the ignition module? I guess not. Oh well, I will work around that.
Thanks,
TOM85CJ7 is offline
post #4 of (permalink) Old 02-16-2001, 01:12 PM
Matt M38A1
Or you could get some plumbing fittings for one of the sensor holes, and plumb it for an air line, then pressurize it to twenty pounds (for water tightness)
post #5 of (permalink) Old 02-16-2001, 01:42 PM
If all you want to do is check your head gasket, just to a compression check on each cyl. You don't need any ign stuff hooked up. You need a big red hot wire for your starter and another hot wire with a switch in it to control the solenoid. Do a leak down test on each cyl and you will quickly notice if you have any leaks! If you don't have a comp checker, they are about $15 at the parts store.
big ed
<font color=red>'88 YJ, 4" susp,3" body,35's,283 Chevy V8,TH350,4.11's,D30,D35c</font color=red>
v8jeep is offline
post #6 of (permalink) Old 02-16-2001, 06:44 PM
Hey- Or buy a radiator pressure tester. It spins on like the radiator cap, then you pump it up and pressurize the system. Matts got the right idea too!
MARK (OIIIIO) LANGMOTORSPORTS
1977/CJ7/GLASSTUB/460CIFORD/C6AUTO/4"LIFT/33'S
post #7 of (permalink) Old 02-17-2001, 03:48 PM
there is a product called wet start which saves you from having to connect the fule lines. Its a spray can that you spary in the carb. hope this helps.
Sold the CJ... Cant wait for the next time around!
timCsjeep is offline
