J-10 T-18 any good?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-15-2001, 05:56 PM
I have the oportunity of trading my t-5 for a J-10 t-18 transmission and I was wondering if this t-18 was good tranny to swap into my 82 CJ-7 and If this is a bolt on
swap.
tks
junior
post #2 of (permalink) Old 02-15-2001, 06:00 PM
Re: J-10 T-18 any good??
Don't have my latest issue with me but JP Magazine just did a tranny swap article that hade some good and bad points about common trannys. Check it out at www.jpmagazine.com
I'm sure they mentioned this one.
'88 Sahara, 4.2, auto.
post #3 of (permalink) Old 02-15-2001, 06:03 PM
ricochet's Avatar
I just did this on Tuesday. In order to put that transmision in you truck, you will need to change the input shaft to either a ford or a jeep cj t18. If your going to use the ford input shaft, you will need a new pilot bushing. Advanced adapter sells them. I'm not too sure about the bell housing, but I had the t-150 trans that had the correct bolt pattern.
Keith
ITS GOOD ENOUGH [img]/wwwthreads_images/icons/wink.gif[/img]
ricochet is offline
post #4 of (permalink) Old 02-15-2001, 06:13 PM
elusive's Avatar
YOU NEED A DIFFERENT X-FER CASE.. THE T-18 ONLY BOLTS TO A DANA 20.. YOU HAVE A DANA 300oops.. sorry bout the caps...
the j-10 t-18 fits fine into a cj-7 as is...jeepgod has it and it gives plenty of driveshaft left...
~~Elusive~~
[img]/wwwthreads_images/icons/tongue.gif[/img]tj-7..tellico tested, uwharrie [img]/wwwthreads_images/icons/tongue.gif[/img]safaried..1 ton drivetrain[img]/wwwthreads_images/icons/tongue.gif[/img]..see it at http://www.jeepgod.net
oh yeah, and a 2000 tj,lift,33's..etc
elusive is offline
post #5 of (permalink) Old 02-15-2001, 06:17 PM
Well the t-18 is installed on a 74 CJ-5, but it has the J-10
tcase and it has a spacer between the tranny and the bellhousing. the owner told me he got the jeep that way and dont know anything on the swap. Also I was checking the
off-road writing about this tranny and I believe this one doesnt have the granny low. Is this true of I just didnt understood the explanation given on this page?
tks for answering my post
junior
post #6 of (permalink) Old 02-15-2001, 07:45 PM
the T18 MIGHT be bolted to a dana 300, since J20 trucks used them 81-83 or so.
but if it dos it will have a long adapter between tranny and Tcase.
and the spacer and bellhousing your talking about will fit in a CJ7 but not in a CJ5.
it SHOULD be a granny low first gear, but MIGHT not be. you have to drive it, or turn the shfts and count to make sure.
either way its way better than a T5 if you have a serious engine or off road habit.
OzarkJeep
"If thats the way that you want it, well thats the way I want it more..."
ozarkjeep is offline
post #7 of (permalink) Old 02-15-2001, 08:01 PM
Tks everybody, will let you know if I do the swap.
tks a lot
junior
post #8 of (permalink) Old 02-15-2001, 08:12 PM
jeepgod's Avatar
if it came from a j10.. it has the granny gear.. and if it has the spacer infront of the tranny.. on the input shaft.. no worries.. will work great in a cj7 as is.. love my set up.. straight from a j10.. more than likely you will need a d20.. its cool.. about the same as a d300.. not quite as low of gears.. but still a real good transfer case..
jeepgod is offline
post #9 of (permalink) Old 02-15-2001, 09:46 PM
I don't believe any T18 from 1980 on came with the dana 300...I maybe wrong but from what I have read they came
with NP208's. If the t18 is from a 258 model it will bolt in with no input shaft modifications.
Alec
'78 CJ7 258 T18/dana 20...dana 30/amc 20 w/ mosers & lockrights...
'glass body w/ tied in full cage...warn x8000i
http://members.aol.com/fastflyn31/page1.html
Alec78CJ is offline
