Question about trans. swap and 8.8 axle - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-14-2001, 07:58 PM
I am really thinking about the TF727 / TF904 swap. currently i have the 904 i know that they are not the same length but will the TF727 bolt up to my dand 300 transfer case with no problems? The tran. is out of a yunk yard so i do not know what kind of t/c was behind it. I guess what im asking is.. will the shaft from the trans. fit into the t/c with out any suprises? Now the axle. I want to up grade my axles when i do my SOA and i now have everything to do my SOA, the ford 8.8 from what i have read on here is a good swap. My question is how wide is the 8.8. I want to put it under my cj-7 will i need to cut it down. Also when i hook up the rear calpiers what do you do with the prop. valve...leave it there or get a adjustable one? what about the lug pattern is it the same as my cj ? Is a waggoneer front dana 44 the same pattern?
84CJ7/304/AUTO.904/DANA300/35'S ALLWAYS TIME TO PLAY!!!
post #2 of (permalink) Old 02-14-2001, 08:12 PM
Re: Question about trans. swap and 8.8 axle
The bolt pattern on the explorer 8.8 that people like to swap is 5 on 4.5. Not the same as your CJ or a Waggie front 44. It is however the same as a YJ's bolt pattern which is why people like to use them in addition to the greater strength.
Do a search on the board on the 8.8 and you will find a ton of info. I believe H8 has a way to convert the bolt pattern. He is also the guy to get the good info on this axle swap from.
'79 CJ-7
ChrisM is offline
post #3 of (permalink) Old 02-14-2001, 08:25 PM
elusive's Avatar
doa search on the tf 727.. the swap has been beat to death on here lately...the dana 300 bolts right up, but has to get clocked(turned) a bit and you need about 4" of lift for it to work well...
~~Elusive~~
[img]/wwwthreads_images/icons/tongue.gif[/img]tj-7..tellico tested, uwharrie [img]/wwwthreads_images/icons/tongue.gif[/img]safaried..1 ton drivetrain[img]/wwwthreads_images/icons/tongue.gif[/img]..see it at http://www.jeepgod.net
oh yeah, and a 2000 tj,lift,33's..etc
elusive is offline
