Engine likes to flood and run RICH starting
I don't really drive my Jeep much, ok - I filled the gas tank up 3months ago, and haven't even run 1/2 a tank out yet! However I do start it and try to drive it around every week or two. I have recently replaced the carb. Carter and when the engine is cold, I pump the gas once, and turn it over. When it starts it seems to idle right around 1100 RPM, however if I make the mistake of giving it any gas it will die, unless I put my foot into it and then it looks like a diesel engine in the garage. After the engine warms up it runs fine.
I am thinking it has to do with the choke. Can you just replace the choke, and how much does it cost. It is hard to tell if the choke on the carb. is getting 12V.
Anyone???
J just
E mpty
E very
P ocket!!
'85 or is it a '98?? Cj-7 33x12x15" BFG 2.5" Rancho 258 T-176 Almost EVERYthing Rebuilt or Replaced
