- + j e e p s p e c s + - - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-12-2001, 07:40 PM
hey, im just interested to see everybodys specs on their jeeps. tiresize, engines, lift, whatever u wanna put. heres me:
2000 navy blue wrangler SE
2.5L 4 cylinder (dont laugh, i just got it)
30" timberline AT
no lift that i know of, i got it somewhat used so im not sure, doesnt look like it
aight now its yalls turn
post #2 of (permalink) Old 02-12-2001, 07:51 PM
joeybcdt
Re: - + j e e p s p e c s + -
If you'll look at other messages on the board. Click on the senders name. It will bring up their profile. Most posters put their specs in their profile.
Joey
post #3 of (permalink) Old 02-12-2001, 08:49 PM
or go to http://www.geocities.com/swbjeep/; several vehicles are described in detail and there are links to homepages that go into the gory details. . . .
Because life has more meaning when you take it in 4lo.
Jay Anger is offline
post #4 of (permalink) Old 02-12-2001, 08:59 PM
1978 CJ7
AMC 304 V8 bored .60 over w/TR Ignition
35x12.50 BFG Mts on Pacer Bulletholes
5in Suspension +2in custom body lift
More to come
post #5 of (permalink) Old 02-12-2001, 09:14 PM
Dirt Dog's Avatar
Here ya go[img]/wwwthreads_images/icons/smile.gif[/img]
1985 CJ7
258 IL6
T5 trans with D300 transfer case
3:31 gears
Dana 30 front / AMC 20 rear-both open
1 1/2" shackles(homemade)
2" body lift(off toyota truck)
stainless double tube bumpers front & rear(homemade)
stainless nerf bars(homemade)
10" wagon wheels
33/12.50's and 35/14's hand cut to my own custom tread
alum. diamond plate rockers(made from f-150 tailgate cover)
alum. diamond plate front frame cover and pedals(made from a quarter inch plate off semi)
ford dura spark ign. with TFI coil , thanks to Aaron(Team Rush)
am/fm cassette stereo
cb
new carter bbd w/o stepper motor
hard top,soft top and bikini top /hard doors
new factory seats
added power steering
grant steering wheel
handmade spare tire carrier
tow hook all the way around
handmade reciever hitch
cheapie console
diamond plate corners
hand throttle (bike parts)
hi-lift jack
small winch
dual fuel pump setup (1 electrical , 1 machanical) both are inline and I have a inline T valve so I can be
a mobile gas station if I need to be
handmade "hypershackles"
4" skyjacker softride lift
drop pitman arm
p/s box brace (homemade)
skyjacker stabilizer
swaybar quick disco's
extended bumpstops
stainless extended brake lines
plenty of extraction equipment and tools
Whew[img]/wwwthreads_images/icons/tongue.gif[/img]
Sounds like the signature of some on on JU[img]/wwwthreads_images/icons/wink.gif[/img](w/o the off-road stuff)
http://home1.gte.net/rythem/davescj7.htm
Dirt Dog is offline
post #6 of (permalink) Old 02-12-2001, 10:39 PM
1976 CJ5 (previously red, in progress of painting yellow)
304 bored(.30 over)
elblebrock cam,manifold,carb
stock T-150 3spd/ 20 transfer case
model 20 rear/ model 30 front
acme hardtop
2 1/2 superlift
33in BFG AT on special offset 10in wheels
and many $$$ of stainless and chrome
76 CJ5 304 "its a JEEP thing, I hope you understand"
post #7 of (permalink) Old 02-12-2001, 10:47 PM
elusive's Avatar
Re: - j e e p s p e c s -
1997 jeep tj. slight body work, some axle improvments, 1" body lift, engine preformance upgrade, auto, stock gears for the axles.
ok.. heres the truth
97 tj frame with SOA and shackle reversal and custom shackles
front axle....dana 60 w/35 spline inner&outers
rear axle.....GM 14 bolt both axles have 4.56 gears and detroits
engine...AMC 304 bored .040 over, balanced, 401 heads, etc..
tranny....tf 727 from a 88 waggie and a B&M megashifter
x-fer case..short shaft dana 300 from a 80 cj
roll cage, optima, panasonic g-shock stereo that got swamped and fried, electric fans, nice round headlight(s), power steering, pwr brakes, 38" swamper tsl/sx on 15X10 beadlock rims, skyjacker 4" springs,
~~Elusive~~
[img]/wwwthreads_images/icons/tongue.gif[/img]tj-7..tellico tested, uwharrie [img]/wwwthreads_images/icons/tongue.gif[/img]safaried..1 ton drivetrain[img]/wwwthreads_images/icons/tongue.gif[/img]..see it at http://www.jeepgod.net
oh yeah, and a 2000 tj,lift..etc
elusive is offline
post #8 of (permalink) Old 02-12-2001, 11:12 PM
motor: ford efi 351w
tranny: np435 with 6.69to1 first gear
x-case: 1980 short shaft dana300
front: 62" wide dana60 with detroit locker and 4.56's
rear: 62" wide 14bolt rear with detroit and 4.56's
tires: 38.5x14.50x15 super swamper tsl sx's
wheels: 15x10 8lug black steel rockcrawlers
susp: soa using cherokee front springs in the rear and wagoneer front springs in the front
extras: autometer guages, rci racing buckets, full cage, onboard air, leverlock, hand throttle, cb, high-lift, a packed trail box, lava-linered tub, body and frame cut and lengthened to a 100" wheel base, ramsey re8000 winch, etc.
brian wilson
80 cj5 "high 5"
stretched to 100" wb
efi351w/np435/d300/d60fr/14br/detroits/4.56/38's
post #9 of (permalink) Old 02-13-2001, 11:45 AM
jeepgod's Avatar
homemade jeep utilizing misc. parts found threw out the eastern sea board..
95 YJ frame.. 91 YJ tub... 78 CJ front clip & tailgate...
D60 shortened 3".. 35 spline/4.10/detroit/5 on 5 1/2 from a 73 jeep truck
D44 78 wagoneer front converted to 5 on 5 1/2/detriot/4.10/getting high steer setup
T-18 6:32 first from 73 jeep truck
D20 twinstick from 73 jeep truck
35x16x15 boggers
sony cd player
autometer guages
full cage
multi mount warn 8000i
78 401 w/rochester quadrajet
wagoneer steering
custom bumpers from angle iron
diamond plate rocker guards.. homemade
full cage..
ALL non-estenial items removed..
Krylon pumpkin orange paint job
15x12 AE 589 rims
and a 63 willys CJ-5 stock..
jeepgod is offline
post #10 of (permalink) Old 02-13-2001, 02:35 PM
'95 white YJ
2.5L 4cyl w/ K&N air filter
5 spd
Stock axles (for now) w/ 4.10 gears
2.5" Rancho susp w/1.25" shackles
33x12.50r15 Pro-Comp M/T on 15x8 black solid (not wagon wheel) steel wheels
Hi-Lift jack
Bestop Bikini top & tonneau cover pretty much year-round (gotta love Texas)
Alpine 3-disc in-dash CD changer w/300 watt amp and really loud speakers & subwoofers (gotta be to hear anything over the noise of the top on hiway)
Custom bodywork (courtesy of trees in Washington state)
If it ain't broke, you took the easy way around.
tx_jeeper is offline
