TeamRush Ignition Upgrade Comparison
*MTjeeper* Asked,
*Sorry to beat a dead horse but...
Whats the diff between the HEI upgrade and the TR upgrade?*
Fair Question...
The "TeamRush" ignition upgrade uses the stock distributor,
(Which is an excellent design, and functions very well, ask any Ford racing guy.)
It uses the stock ignition module, and all of the stock wiring harness.
All you change is the distributor cap, rotor, plug wires, and if you can afford it, the ignition coil.
The stock type distributor will keep the vacuum advance where it's supposed to be, the centrifugal advance were it's supposed to be, the install height where it's supposed to be, the oil pump drive in the correct location, and will virtually eliminate the problems with the Jeep version of the Motorcraft/ DuraSpark ignition (namely, small, unvented distributor cap, short rotor, old style plug wires, and the factory canister coil)
The upgrade includes:
-Larger & Taller Distributor Cap, spreads the terminals out and cuts way down on cross fire and chain fire.
-Taller Rotor, keeps the spark energy from jumping from the rotor to the distributor chassis (Ground) inside the distributor. Cuts way down on misfires.
-Better cap terminals, Accommodate the 'HEI' style plug wires, and don't hold moisture or debris in the distributor cap.
-TFI ignition coil, is about 1-1/2 more potent than the canister coil.
(The TFI coil will increase all of the important factors of spark energy, Voltage, Spark Duration and Amperage.)
For a world class- High Performance ignition capable of 15,000 RPM, you can use an MSD 6 series ignition module, WITH ALL OTHER COMPONENTS BEING STOCK, and your ignition system will beat any other ignition on the market.
(If you can prove that any other $130 improvement will do a better job, I'll buy it for you.)
You are using a distributor that was designed and tested for your engine.
You are using a distributor that with the upgrade parts coming from somewhere like MSD, the upgrade is 50 State Emissions Legal, and CARB certified.
All upgrade parts can be bought over the counter at any discount auto parts store in a pinch, no exotic parts of any kind used in the basic upgrade.
Easy for an amateur to do in the drive way in under two hours, even if you rode the 'short bus' to school...
(Ignitions For Dummies...)
Look for $100 for the basic upgrade (performance well above the GM HEI),
And around $200 for the MSD version of the upgrade parts (Emissions and CARB Legal)
The basic MSD 6A module runs about $130, and the top end, the MSD Off-Road Module is about $240.
The GM HEI ignition, and ALL of it's clones are from a defective design to start with.
The GM HEI was designed in 1966, went into limited production (with points to trigger it) in 1972, and was used in all GM vehicles by 1974 with an electronic trigger.
GM could never design out all of the defects, so the entire Coil-In-Cap design was scrapped. GM now uses an ignition very similar to the Ford ignitions.
The GM HEI was never accurate enough to adequately trigger a computer system (or high performance engine).
The GM HEI is NOT designed to work with your engine.
The GM HEI is NOT Emissions or CARB legal in any state.
The GM HEI / Hybrid For Jeep is comprised of mismatched parts, plugged into an engine it's not supposed to be in, and 9 times out of 10, is supplied by power wires too small to adequately feed the ignition.
Changing over to a GM HEI system will require either an investment of about $400-$600 to purchase the distributor and support gear, and it will require scrapping the entire stock ignition system, and starting from scratch.
(I have not seen one single web site yet that installs the GM HEI correctly.)
A word about aftermarket ignition parts...
The most common mistake most people make is to think that something in a flashy box, or with a racy name and high price tag is 'Better' that stock parts....
MSD 'Blaster' and Accel 'Super Stock' ignition coils are exactly the same thing...
Factory type premium coils with pretty paint and a sticker, .... and a doubled price.
HEAR THIS...
ANY PREMIUM DISTRIBUTOR CAP WITH BRASS TERMINALS WILL WORK JUST AS WELL AS THE 'HOT SHOT' BRANDS.
(All are manufactured in the same factories.)
ONLY MSD IS 50 STATE EMISSIONS AND CARB LEGAL. They have done the testing and received the certification.
ANY PREMIUM FACTORY REPLACEMENT STORE BRAND IGNITION COIL WILL WORK AS WELL AS THE 'HOT SHOT' BRANDS.
Borg-Warner, AC Delco, Motorcraft, and a couple of others make ALL of the premium and factory stock ignition coils in the United States, so no matter what brand you buy, you are getting one of about five major manufacturers.
(If you buy the 'Economy import coil, then you get what you deserve...)
THERE IS A DDIFFERENCEIN PLUG WIRES!
In most cases, the premium, lifetime warranty store brand of plug wires will work just fine with stock type ignition systems.
The 'Hellically Wound' type of wire is ppreferredover all other types.
NEVER USE SOLID CORE WIRES ON AN ELECTRONIC IGNITION !!
For High Performance Ignitions, As Of The Writing Of This,
MSD Makes The Finest Plug Wires Available. The 8.5 MM wire sets are the lowest resistance, lowest noise (both RF and EM), and the highest voltage with the best insulation that I've ever tested.
At about $60 to $80 a set, they are NOT cheap, but will last a very long time, and are well worth the money if you need them.
