full width axles on wrangler - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-23-2001, 12:42 PM
can I run a front dana 44 (chevy) front, and a matching rear axle without narrowing? By may calculations, the existing spring pads on the 44 axle are only about 1" wider than those on a stock wrangler so I am not really worried about that. I also want to run a 305, sm465 for tranny and tcase. Will I have a front driveshaft clearance problem? Or will it clear ok? Anyone done this before, on a wrangler?
Dan
post #2 of (permalink) Old 01-23-2001, 01:41 PM
elusive's Avatar
Re: full width axles on wrangler
the spring perches for my chevy axle were closer that that.. i bolted the axle right in no mods to the perches. the sm465 tranny is fine.. if you are using an np 205, there will be no clearance problems except for ground clearance!!. the np205 hangs down a long way under a jeep..sure is strong though.
~~Elusive~~
[img]/wwwthreads_images/icons/tongue.gif[/img]tj-7..tellico tested, uwharrie [img]/wwwthreads_images/icons/tongue.gif[/img]safaried..1 ton drivetrain[img]/wwwthreads_images/icons/tongue.gif[/img]..see it at http://www.jeepgod.net
oh yeah, and a 2000 tj,lift..etc
elusive is offline
post #3 of (permalink) Old 01-23-2001, 02:55 PM
Elusive, you keep mentioning that yours bolted in with no problems. What you fail to mention is that you are using a TJ frame which is wider. I'm not trying to be nitpicky, but your lack of info could be misleading.
'75 CJ5,258 w/Howell EFI,T18a,4.27's,33's,On-board air,Warn 8274
post #4 of (permalink) Old 01-23-2001, 05:28 PM
elusive's Avatar
is a tj frame wider than a yj frame?? i really thought they were the same...only the cj frame was more narrow.. i know the tj and yj are the same width in the back, and i thought they were the same in the front too.
~~Elusive~~
elusive is offline
post #5 of (permalink) Old 01-23-2001, 08:13 PM
I will double check my measurements, but it sounds like the YJ frame is an inch narrower than the TJ. The CJ frames are indeed considerable narrower than the YJ, like 4 inches at least. Elusive, have any pics of your Jeep with the full width axles? How wide is it?
Dan
post #6 of (permalink) Old 01-24-2001, 06:01 AM
elusive's Avatar
do a search o my posts or check out the website below.. lots of pics
~~Elusive~~
elusive is offline
post #7 of (permalink) Old 01-25-2001, 11:46 PM
is it really that easy? i was told that you had to move the springs outboard for some reason.
post #8 of (permalink) Old 01-26-2001, 04:55 AM
jeepgod's Avatar
on a cj you do have to move the springs outboard.. a yj you shouldnt have too.. since they are 4 inches wider.. i have a yj frame and a wagoneer axle full width in the front.. granted... its not quite as wide as a chevy d44..
jeepgod is offline
post #9 of (permalink) Old 01-28-2001, 05:06 PM
elusive's Avatar
i finally got off my lazy but and measured a yj and my tj frame today.. they are identical in width and length front and rear. therefore.. it is a true statement that a chevy full sive axle out of an 83 pickup will bolt right into a yj...although the diff is on the wrong side. the spring perches dont have to be moved and are the correct width, the brake lines will fit and are long enough. the rear axle is also a direct bolt in, but you'll have to grind the perches for a better angle on the rear pinion.
seems like my next jeep i build will have a yj frame with these same axles, a 4.0 and a dana 300 x-fer case.. little work...much strength
~~Elusive~~
elusive is offline
post #10 of (permalink) Old 01-28-2001, 05:48 PM
Elusive,
How did you convert the chevy front axle over to the type of steering you need on the wrangler?
